Question about Audio Technica Audio Players & Recorders
Audio technica turntables issue AT 60-LP usb the start and stop buttons no longer work the drive doesn't turn. Belt is fine. the wires that push internal mechanisms are no longer connected. Help
  • Audio Technica Master
  • 5,699 Answers
There are a number of helpful videos on YouTube about this model turntable, it might give you the answer you need.
Posted on Feb 28, 2016
Testimonial: "Thanks I took it in to be serviced. The transformer had blown. It works really well now"
5 Suggested Answers
Anonymous
  • 5 Answers
SOURCE: Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Posted on Sep 18, 2008
Anonymous
  • 515 Answers
SOURCE: Phono Preamp buzz
Ditto. Double check the ground cable. If it is connected, then try a different set of RCA cables. Also check the connections on your headshell/cartridge. Make sure all 4 wires are properly secure.
- OPTiC
DJ PRO LAB
DJ PRO AUDIO
Posted on Oct 08, 2008
Anonymous
  • 7 Answers
SOURCE: Sony PS-LX5 Turntable
It might be the moter , through it in the bathtub and see if yousee sparks.
Posted on Nov 08, 2008
Steve W
  • 104 Answers
SOURCE: The turntable for Crosley Radio CR66 will not work.
http://www.archive.org/details/Turntable_Belt_Installation
Posted on Feb 22, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Posted on Apr 24, 2009
Where is the audio output hole on the Audio-Technica At LP-120 USB turntable, so I can connect to my stereo system?
After reviewing some of these unit being sold on e-bay, I found some pictures that show the cable coming out of the bottom of the unit. I then went to this site
The most detailed Audio Technica AT LP120 USB Review and according to them, the cable is hard wired. This means the cable is not removable. If your unit does not have the rca cables coming out of the bottom of the unit, it may have been cut off.
Jan 03, 2018 | The Audio Players & Recorders
My turntable doesn't rotate any more...
Hi, the transformer that supplies power to the motor has been fried by the 220v input and will need to be replaced. If you remove it and go to your local electronic parts supplier they should be able to sell you a replacement. Cheers John styluscity.com
Dec 04, 2011 | Audio Technica ATLP120USB Turntable
I bought an Audio Technica USB AT LP 120 Turntable last June. It worked fine as a turntable, but I was never able to get good recordings of vinyl without distortion. But now I have another problem: when...
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Dec 05, 2010 | Audio Technica USB Turntable
Turntable turns on, but when "start" button is
Pull the aluminum record platter where the record sit on and check to see if the belt off. If it is broke you may need a new one.
Dec 02, 2010 | Audio Technica AT-PL120 Turntable
My audio-technica PL50 plays 45s at the wrong speed.
believe it or not not it probably doesn`t even play your lp`s at the right speed? Its probably because your drive belt has actually stretched? rubber belts do wear and maybe seek out a replacement drive belt?
try this company?
mailto:[email protected]
May 19, 2009 | Audio Technica AT-PL50 Turntable
Audio technica lp 20 usb the belt is out of place and I do not know how to put it back as it was
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Oct 11, 2008 | Audio Technica AT-PL120 Turntable
Audio Technica AT-LP2D
Mine had the same problem. It was under warranty and Audio-Technica replaced it promptly.
Mar 02, 2008 | Audio Technica AT-LP2D Turntable
440 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
