SOURCE: When bike gets worm it runs like ****
Since you have thrown the entire ignition system at it, let's think about fuel. If you were running out of gas it would act as you described. I would start by removing the float bowl. Be careful not to spill any gas because we want to look at the level. It should be over half full. Check the float movement. You should be able to push it up without resistance. Looking from the bottom remove the phillips screw that retains the float axle and the float and needle valve should fall out. If the needle valve has three sides or if the rubber tip is worn, replace it. The 3 sided valves have a tendancy to stick closed and all dealer stock should be the 4 sided version by now. After you re-install the float, leave the bowl off and follow the small vacuum hose from the petcock to the carb. Pull it off at the carb end. Look to make sure it isn't damaged. **** lightly (sorry) or use a vacuum pump on the hose. With the petcock on and gas in the tank, a healthy stream of fuel should pour from the needle valve. If not, the petcock diapragm is shot. If none of this helps, take it for a ride and when it acts up, crack the fuel cap loose and if it takes off the vent in the cap is malfunctioning.
SOURCE: Distributor wont spark
check the fuseble link.
you can measure it, and make sure the contact are clean and secured.
the other thing is the check the ignition switch, make sure you have 12v going to the switch.
check thermo switch on top of the block.
SOURCE: 89 jeep cherokee 4.0 cranks and gets fuel but no
If you can access a good engine control module (computer) replace it to your unit and try starting the engine again.
