Question about Kohler Electrical Supplies
XT7.75. Why won't it start?
It had fuel and oil
Posted by Judy on
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
97 mercury mountaineer. won't start
hi,
watch your oil pressure when cranking, you have to have some oil pressure to get the fuel system to start. you may have to find the hot wire at the relay and energize it to see if it is indeed the fuel pump going out. if its been sitting and its a 97 the fuel pump just might have went, you can also try hitting the gas tank from the outside in the middle to see if that works too. have a water hose or fire extinguisher around when your working on fuel system and leave one of your battery cable a little loose..
jm
Jul 04, 2017 | 1997 Mercury Mountaineer
93 chrysler t&c awd changed fuel pump and filter, van ran fine again for about 2 months now won't start and don't hear the fuel pump. changed the oil pressure sending unit and still won
fuel pick-up in tank is blocked it has a sock over the end as a gross filter to keep out any big junk from getting sucked into the pump and causing damage to it. the sock can get so plugged up that no fuel will flow, causing the pump to run for a short time then with no fuel flow to cool it it trips the safety and shuts off
Aug 12, 2012 | Cars & Trucks
I changed the oil in my 98 concorde and now it wont start. The oil light is on but not the check engine light.\
do you here the fuel pump working when you turn the key?If not could be a fuse that runs the fuel pump.
Aug 05, 2012 | 1998 Chrysler Concorde
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Jan 01, 2018 | 2002 Saturn Sl
Just changed oil in 2004 Volkswagen jetta. now car won't startled
Are you absolutely sure that you put the right weight oil back in the car? These cars are very sensative to this and if it doesn't see the correct oil pressure it won't start beacause it uses oil pressure to fire the fuel injectors. You need to be using 505.01 oil in your car only. Anything else can cause a no start or major engine damage!
Jul 03, 2011 | 2004 Volkswagen Jetta
Gas and oil mixture in car, car won't start?
BAd headgasket or you have a bad cylinder. You need to have a compression check done on your vehicle
Jun 24, 2011 | 2003 Mitsubishi Montero Sport
Electrical Supplies Logo
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
