Sometimes we may come across some PDF materials which were download from the internet or sent by others. They are easy to read by free Adobe Reader yet some of them were password protected from opening, copying and printing. It is really tough if you urgently need to copy or print some PDF files. So is there any method to remove PDF password? The answer is yes. But first we need to know some definition about PDF password.
Generally speaking, there are two types of password provided by Acrobat PDF standard security. They are "user password" and "owner password". "User password" is also called open password, it is the password defined by the people who create the PDF file which is used for protecting the PDF files from opening by others. Only people who enter the password can open the protected PDF files. "Owner password" is the password that set to protect the PDF files from changing by others. With an "owner password", the owner can protect the PDF files from printing, editing or selecting text and graphics.
So it turns to know how to remove password from PDF. Here is a small and easy-to-use PDF password remover which can help us do this work. Of course first you need to download this
PDF password remover and install it on your PC. Then we can get start.
Step 1 Launch PDF Password Remover Double click the start icon to launch
PDF password Remover.
Step2 Import PDF files
Click Add and browse the local PDF files need to be decrypted. It allows you to import 200 files at one time. After the files are imported, the file information will be shown in the panel.
Here you need to note that this PDF Password Remover can remove "owner password" directly. While for the PDF files with "owner password", you cannot remove the password unless you know the password. The "owner password" protected PDF files is shown in the pane with a lock beside. If you need to remove the "owner password", just click on the lock beside the file in the pane and key in the correct password in the pop-out small window box and click
OK to confirm the password.
Step 3 Decrypt PDF filesClick the
Start button, and soon you can get the decrypted PDF files.
Also there is a quicker way to remove PDF password with this PDF Password Remover, just right-click the protected PDF file and choose
Decrypt with AnyBizSoft PDF Password Remover in the shortcut menu, you can remove the password from protected PDF file without launching the program!
Sincerely hope this tip can do you much favor to learn how to remove password from PDF.
