Order this replacement remote, the power button controls the flame, the up button control the backlights and the heat button turn it on/off. You will have to manually turn the heat on from the unit.
Remote Control for Great World GW-6088TBT Bluetooth Electric Fireplace Heater https://a.co/d/2sEWL1c
Remote Control for Great World GW-6088TBT Bluetooth Electric Fireplace Heaterhttps://a.co/d/2sEWL1c
The very 1st color setting (as well as The very 1st backlight setting) will enact "color changing mode". This ONLY works at the beginning of the sequence.
Wait 15 secs to see colors change..
0 = lights off
1 = lights on & color changing is active
2 = color 1
3 = color 2
4 = color 3... and so on.
I bought a great world ltd swe067b electric fireplace ... - Fixya
www.fixya.com/.../t25420081-bought_great_world_ltd_swe067b_electri...
Feb 12, 2015 - i bought a great world ltd swe067b electric fireplace a couple of months ago.it wont ... Purchased a great world model swe071 electric fireplace. Howdo you control the feature to make the flame colors change automatically ..
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
SOURCE: Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
SOURCE: I purchased an Electralog Electric
Hi Ron,
I found a manual for Electralog Fireplaces here. It seems to be rather generic, but hopefully answers your questions about the appliance.
As far as your remote control device goes (and possibly a model specific manual) , the manufacturer's info in the manual provides this for contact:
Dimplex North America Ltd.
1367 Industrial Road
Cambridge, ON N1R 7G8
Canada
Customer service:
1-800-668-6663
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Technical specialists:
1-888-346-7539
Monday - Friday
I hope this helps & good luck!
Did you find out how? I have one and need to know I don't have remote
