Hi there, I launched my MS Outlook some days, it says me that .pst file is corrupted. I searched over Internet about this issue, applied SCANPST, but tool didnt help me. I reinstalled ms outlook, but there was no result. May be, does someone here know the resolution? Thank you in advance....
The Microsoft repair tool is the only one that works - and you have to create a new PST file, and recover items from the old one. Some items will be recovered - but I never get close to 100%....
If it didn't help try to use Recovery Toolbox for Outlook designed for Microsoft Outlook database repair if PST file damaged. Outlook fix tool can solve the problem of corrupted Outlook databases and fix errors. For more: The one tool that knows how to fix Outlook 2003 corrupted files in fast...
Repair an Outlook data file (. pst) file
There are two methods available to recover corrupted PST files. First Manual takes multiple steps to recover and the second third-party tool opens your corrupted PST in a new PST.
You can also test the free demo version of the solution and recover 20 items from each mailbox. Read more: https://www.mailsdaddy.com/outlook-pst-repair/
For instantaneous repair of damaged Outlook PST files, Outlook PST repair has been intricately designed. The software recovers and restores Outlook mailbox items like emails, notes, attachments, calendar, contacts, and journals completely and accurately. It helps to fix PST size limitation errors, and to recover deleted Outlook items. Apart from technical features, other features like user-friendly GUI and descriptive screens also assist user in fixing complicated PST issues. http://www.thebestcomparisons.com/pst-recovery.html
If you want to fix PST corrupted files then you can use the manual method by using inbuilt Scanpst.exe which can repair the file, but this manual process is complicated and irritating then you can you third party PST repair software to repair the PST files error easily
For more info:- https://www.shdatarescue.com/pst-repair/
If you are facing any error in accessing your important PST data, then there might be corruption issues with the PST file. I would suggest you use PST Recovery Tool which can easily repair all the corrupt or recover the accidentally deleted files without any hassle.
For more info, read - https://www.data-recovery-solutions.com/pst-recovery.php
Check out this Microsoft Support procedure https://support.microsoft.com/en-us/kb/272227
Do a checkdisk on your hard drive to make sure you dont have any corrupted data. Right click Drive C, Properties, Tools, Error Checking, reboot and watch the check process to see if you notice anything bad.
Bedsides that I recommend to restore one from your last backup, you do have a backup, right ? . . . . .
There is no need to get tensed even if you are facing the PST file corruption. In fact, if you are looking for an option that can facilitate you to fix PST file corruption, then you can help of Kernel for Outlook PST Repair software. With the help of this proficient PST recovery software, you can successfully repair corrupt PST files very easily and instantly. The utility can even restore emails even if PST headers have got damaged.For more information http://www.pstrecoverytool.net/
