1993 Subaru Impreza Logo
P
Peter Manning Posted on Oct 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changed light bulb on 1993 subaru impreza now car won't start, everything lit up on the dashboard
Just changed the head light bulbs and they came on fine but the everything on the dash board started flashing and now the car won't start, please help
Claude Kayser
Level 3:
Top Expert:
  • Subaru Master 9,098 Answers
  • Posted on Oct 24, 2015
Claude Kayser
Subaru Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066343
Points
28436
1993 Subaru Impreza Won't Start! - NASIOC
forums.nasioc.com > ... > NASIOC Technical > Service & Maintenance
Sep 12, 2004 - 3 posts - ‎3 authors The car has been running fine, but recently in the morning especially, it won't turn over. I crank it and its trying to start, but there is no spark. Car won't start, cranks but no start. - NASIOC - North ...
Aug 26, 2013
car wont start, getting fuel and spark - NASIOC - North ...
May 22, 2012
HELP: Car won't start after timing belt change - NASIOC ...
Sep 23, 2008
Weird starting problem--1993 Impreza - NASIOC ...
Mar 4, 2003
More results from forums.nasioc.com
my 1993 impreza wrx wont start please help - ClubWRX.net
www.clubwrx.net/.../134323378-my-1993-impreza-wrx-wont-start-pleas...
Dec 5, 2009 - 7 posts - ‎2 authors can anyone help me, my 1993 impreza wrx wont start, 2 days ago i went to ...ClubWRX Forum - Subaru Impreza WRX and STi Community and ...
How to change light bulb in a 1997 Subaru impreza
Remove cover at back of light ,remove wire clip that hold the globe in then remove globe and replace .
1helpful
Subaru tail lights
Check to make sure the bulbs are good. If they are make sure the fuse is not blown. If its good check for power to the rear sockets.
Let me know what you find and I'll see if I cant help you figure this out.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
Brake lights won't work on 93 Subaru impreza. Fuse ok, bulbs ok. Brake light switch replaced 1 yr ago
Mr. Williams since you tried with fuse,bulbs and brake light switch with no success,why you do not try to check your circuit by using a tester and see whether you have any broken wire or bad earth?
2answers
2helpful
2answers
Clear moist inside headlights of Subaru Impreza wrx 2008
first remove the bulb of the headlights then you can use a rag and a long stick, a screwdriver will do. put the rag infront of the screwdriver then wipe all the moist carefully. you can try leaving it to dry up too just leaving the bulb socket open, it will just take time
2007 subaru outback headlight problem
Each head lamp also has it's own relay, you can rule the relay out by swapping the left head light relay with the right head light relay & see if the problem moves to the other side...The relays are also in the same under hood fuse box.
2helpful
Changing the park and spotlight bulbs on 1996 Impreza WRX
i had the same problem with my 2003 wrx you have 2 choices on how to fix it the first is take the car to a subaru dealer and they can do it for you. Or you can do it yourself like this under the bonnet at the front of the grill you'll see a row of clips first you have to pop them out to remove the grill fully from the car that will give you access to the 3 or 4 bolts holding the light to the car you have to undo these bolts and remove the entie light from the car this will give you fully access to the park light fixture simply twist it so it pops out the headlight and replace the bulb ..... the spot lights are the same remove the grill and the headlight from the car this makes a gap if you look threw and down this gap you will see the back of the spot light fixture simply twist (unclip it depending on the year of the car) it to remove it and replace the bulb once you have done this bolt the headlight back in and clip the grill back into place
Top Subaru Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Oliver Street
Are you a Subaru Expert? Answer questions, earn points and help others
