You can change how your tv displays in the video setting menu under display. You will have a choice between 4:3, 16:9, 16:10, cinema or automatic. I think to fill your screen the best you should choose 16:10 but this is not going to guarantee that all channels will fill the screen. It still has to do with how it is being broadcast to you.
get the on screen menu on the screen
scroll around till you see aspect ratio and click on that use the buttons to change ( you will see the changes on the screen)
click ok and exit when satisfied
Fir aspect ration to change there can be a few reasons
some tv stations produce movies in the wrong ratio and it shows up for the movie as black edges or tall figures or fat figures ( change channel to verify)
or there can be a fault occurring in the board of the set that will not hold preset aspect ratios
you probably have it set on wrong aspect ratio, go to menu/picture set it to auto it will then chose the right aspect ratio of the prog being shown/transmitted, if you have other devices running through it, make sure they are set to 16.9 or it will never look right, it is a simple mistake, sometimes there is 1 prog that never looks right, you can then roll though the pic settings manually, tiil you get the best fill of the screen, 4.3-16.9 14.2 Cinema-subtitles-etc cinema would give u a full screen of 4.3 but cut a bit off top & bottom, nothing is perfect with all the different aspects but Auto wiil do its best.
That is probably due to the transmission or aspect ratio of a dvd etc and perfectly normal but annoying! Try setting your TV to automatic aspect ratio, if it has one. Happy New Year.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
IF tv can take 1080p use this setting you will see blank screen if not the blu-ray will set up the best resolusion for tv usely auto mode and the ratio dipends on what size screen you want to watch playback in
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
