Here is the manual that will help you sort it out.
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
I think you have a photo cell or fuel issue as it ignitor trips but you do not get fuel.
Make sure you check the seal in the tank cap (Closed tightly) and the 2 hoses from the tank for cracks. The fuel system works via the 2 tubes. One is pressure the 2nd is fuel supply. Any leaks via either hose or the fuel cap will prevent fuel flow.
You may have to clean the fuel nozzle also. Just make sure to clean the photo cell carefully before putting it back together.
Unless you have an air filter(s) that is horribly clogged taking care of the above should get you going again.
Thanks for choosing FixYa,
Kelly
