Question about Toshiba Cameras
How do I record a tv show to a memory card from the Toshiba t.v..?
Posted by Vincent Hunter Sr. on
My TV uses antenna only and I want to record TV programs. Is there a DVR that will work for me? (the Toshiba DVR 620 that I just purchased will not connect to my TV antenna unless there is an access
I use a TiVo roamio basic, it can record up to 4 programs at once and has a 500gb harddrive and is made for OTA, but can also use a cable card. Check it out on eBay.com or TiVo.com.
Ray
Oct 06, 2014 | Televison & Video
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Is the memory card removale
Yes, the memory card is removable. The following web site gives different cards.
http://support.nikonusa.com/app/answers/detail/a_id/16778/~/approved-sd-cards---coolpix-s4000
The following is a list of approved memory cards for the Coolpix S4000 digital still camera. These cards have been tested and approved for use with the Coolpix S4000.
The S4000 uses SD (Secure Digital) memory. Memory cards with an SD Speed Class1 Memory of 6 or faster are recommended for recording movies. Movie recording may stop unexpectedly when memory cards with a lower Speed Class rating are used.
SanDisk 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 TOSHIBA 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 Panasonic 2GB2, 4GB3, 8GB3, 12GB3, 16GB3, 32GB3 Lexar 2GB2, 4GB3, 8GB31 Specification defining minimum data transfer speeds for SD and SDHC memory cards.
2 If the memory card will be used with a card reader or similar device, check that the device supports 2 GB memory cards.
3 SDHC Compliant. If the memory card will be used with a card reader or similar device, check that the device supports SDHC.
Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
Jan 06, 2011 | Nikon Coolpix S4000 Digital Camera
I own a D-VR7KC2 DVD VIDEO RECORDER / VIDEO-CASSETTE RECORDER TOSHIBA, the problem is I can record only some of my DVD's to the VCR, on certain discs a red circle with a red line through it shows up on the...
You must have a show that has an anti-copy signal imbedded into the show causing it to not be recorded. This is due to DRM rules on copy right materials.
Sep 10, 2017 | Toshiba D-VR4 DVD Recorder/VCR
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Toshiba D-R410KU DVD recorder, How do I set it up with a regular TV and no cable box? I want to record regular TV shows and I receive only local station via Rabbit ears .
No offense intended, but...get a life and a new TV and a cable box with DVR...pre-record your shows and later record on Toshiba DVD recorder using HDMI cable, available at Fry's for $10. Also, you might still be able to do what you want if you are willing to read every word of every page of the user manual...been there done that...it wouldn't work for me either until I did same...I know, only read the user manual as a last resort, so...
Oct 08, 2008 | Televison & Video
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Cameras Logo
Top Toshiba Cameras Experts
Lawrence Oravetz
Harrie
ray gallant
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
