The three LCD panels are located just before the prisme. I needed to change one panel, then i have to align the three beams.
SOURCE: Alignment
Did you mess with the alighnments?? I doubt that just an alighnment will help as they do tend to drift but all three tubes dont go out of alighnment unless something happens to the circuit. If your a technician then sure you can replace the convergence ics but if your not its not like replacing spark plugs in your car. Electronic repair is a trained trade. Its not something we can teach you overnight or even in a month. Im sorry but If you are not a tech you should and its highly advised that you do take the set to a pro to have rthis problem fixed as theres very high voltage in these sets that can hurt you very badly.. Good Luck
SOURCE: Hitachi 50" - 50GX30B
One of your convergence IC's has burned out and needs to be replaced. A good rule here is to go ahead and replace both STK392-110 IC's with the new improved STK392-150's. If you have never replaced convergence IC's and realigned convergence circuits, allow a qualified tech to handle it for you.
SOURCE: Hitachi 50GX30B I need to align Digital Array no original remote
Unfortunately, it looks like you will need the original remote. I found one at www.remotes.com Give it a try. Good luck.
SOURCE: Red Curved line
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
SOURCE: Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
