Royal Cash Register 500dx Logo
Shane Lynch Posted on Oct 23, 2015
Asking for sec code when i try to print z report
Hp cm4540 configration device code
Not sure if you just want to print a configuration or if you have an error code. To print a configuration page
  1. Scroll to and touch the Administration button.
    1. Open the following menus:
    1. Reports
    • Configuration/Status Pages
    • Configuration Page
  • Touch the Print button to print the report, or touch the View button to view the report on the screen. The report consists of several pages.
    I
    How to print database in vb
    To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
    Printing a Data Report
    Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
    Choosing to Display a Print Dialog Box
    When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
    To display the Print dialog box
    1. Add a CommandButton to a Form.
    2. In the button's Click event, place the following code.
    DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
    Note Printers must be installed on the computer in order to present a choice of printers.
    Printing Without a Dialog Box
    In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
    To print without displaying the dialog box
    2. In the button's Click event, place the following code:
    DataReport1.PrintReport False
    Or, to specify a range of pages to print, use the code below:
    DataReport1.PrintReport False, rptRangeFromTo, 1, 2
    How do you Z out a 435dx
    "Z" (Prints End-of-Day Management Reports and Resets Totals) - Prints the "Z" management report at the end-of-the-day and resets totals to zero (except "locked-in" grand total).
    To print Management Reports, slide the control switch to the "X" or "Z" position as needed, then press the [amt tend/TOTAL] key. Refer to explanation starting on page 37.
    "X" AND "Z" SALES MANAGEMENT REPORTS
    __________________________________________________________________
    Transaction data is maintained in the memory of the cash register as long as the battery back-up system is in effect. This data can be printed as a report for management review.
    The Management Report can be printed from either the "X" or the "Z" position on the Control Switch.
    "X" POSITION REPORT (Refers to a mid-day reading)
    The "X" position report prints the accumulated information and RETAINS ALL TOTALS IN MEMORY. Use this position to print periodic readings of transaction information at any time through-out the day. (Some users call the X-report a mid-day report).
    "Z" POSITION REPORT (Refers to an end-of-day or close-out reading)
    The "Z" position report prints the same information as the "X" report. However, once this report is printed, ALL TRANSACTION TOTALS ARE RESET TO ZERO except the Grand Total. (Some users call the Z-report an end-of-day report).
    NOTE: To prevent accidental printing of the "Z" report, set the security code as explained in the SECURITY CODE section.
    Once this code is set, a "Z" report will not print until the security code is entered. If a "Z" report is attempted without entering the security code, the prompt "SEC Code" will appear in the display.
    PRINTING THE SALES REPORT
    IMPORTANT: Once a "Z" reading is taken, it cannot be duplicated, so be sure to have plenty of paper in the register.
    1. Set the Control Switch to either the "X" or "Z" position.
    2. Press the [amt tend/TOTAL] key.
    NOTE: If a security code has been assigned, be sure to enter the security code before pressing the [amt tend/TOTAL]
    key.
    TO CLEAR THE GRAND TOTAL:
    1. Set the Control Switch to the "prg" (Program Mode) position.
    2. Type [2], type [0], then press [RA].
    After this operation, the grand total resets to zero.
    How to print report ?
    what kind of report .if u wanna print counter then press the stop button for 3 secs and then press start to get report
    How do you get a printed confirmation of a sent fax? Cannot find the answer in the manual. Thanks
    In setting mode , Go to report setting and inside that go to Tx report or transmission report ,or sent report or like the same (depends on brand and model).then set it on and then every time you sent a fax, a report will be print to show confirmation or any error. pls try to clear you model no. and brand name whenever you would like to ask question.
    2answers
    Will not come out of please wait condition and never codes out.
    You may have a bad hard drive or need to re-intall the firmware.
    2helpful
    2answers
    How can i get a fax from memory.
    Solution: Printing reports and lists MX310
    Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
    Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
    LIST
    Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
    REPORT
    Prints after transmission of a document.
    You can enable or disable this feature, or set the machine to print a report only when an error occurs.
    You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
    RX (Reception)
    REPORT
    Prints after reception of a document.
    To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
    2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
    3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
    Sharp copy/printer to staple Crystal Reports
    this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
    6helpful
    5answers
    Repeated Fax TX report printing
    Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
    My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
    Here's what I did...
    Go to: Fax Menu
    Arrow right ( >) to Maintenance/Settings, hit, 'OK'
    Arrow right to (>) to Device Settings, hit 'OK',
    Fax Settings, hit 'OK',
    Arrow down ( v ) to TX Settings, hit 'OK',
    Arrow down ( v ) to TX Report, OK
    Select 'Print error only', hit 'OK',
    Attach TX image, Select 'NO', hit 'OK"
    With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
    Activity Reports
    First of all, Back up your configuration by printing it.
    [Menu] --> [Reports/Lists] --> [User Data List]
    then go back to main menu
    [Menu] --> [#] , it will display #SSSW
    Use the [+] [-] buttons till you see [#CLEAR]
    Press [OK]
    That resets all the configs and status flags.
    With the initial config in hand, you are ready to setup you device and we all live happily ever after.
    Try it out, it works perfectly and on most models
    Top Royal Retail Supplies Experts
    ADMIN Andrew
    ADMIN Andrew
    Don A
    Don A
    Alex Kimuyu
    Are you a Royal Retail Supply Expert? Answer questions, earn points and help others
