wikiHowhttps://www.wikihow.com > ... > Cell Phones
11 steps
1.
Turn off your Alcatel phone. Tap and hold the Power button until the screen shuts down. When the screen completely fades to black, then it is already off ...
2.
Press and hold the pound (#) key and Power button at the same time for about 3 to 4 seconds. You will be prompted that all the data will be deleted. If ...
3.
Select "Yes" to delete all data. Use the phone cursor on your keypad and scroll down to the "Yes" option. Press the OK button to select it. The OK button is ...
Try a hard reset which clears everything off the phone and reloads the operating software. You can do back up in the settings and then restore your data.
You can do it by hard reseting your phone & wiping all your data. To do this follow the below steps :
Start by switching off the cell phone by holding the Power key
In the next step press and hold Volume Up + Power button for a couple of seconds.
Release held keys when the Recover Mode appears on the screen.
Use Volume buttons to sroll to option "wipe data/factory reset", and confirm that with Power button.
Choose "Yes" from the menu, and confirm it with Power key.
Now accept option "reboot system now" using Power key.
Success! The hard reset has just been performed. https://support.bell.ca/mobility/smartphones_and_mobile_internet/alcatel-onetouch-idol-x.how_to_perform_a_hard_reset_when_my_alcatel
A couple of preliminaries: Always have the phone powered off before removing the battery. That means more than having the screen black. You have to hold the power
Here is a first look/unboxing video about the phone.
Hi Esther, You will need to wipe all data and do a factory reset! To do this press the volume up key and the power on button at the same time until the screen lights up!
The power cells may be bad will not hold a charge. If you are plugged into the house power outlet using the Power Adapter, it could be defective. Check both conditions.
your not getting fuel threw the carb see if it is getting to the carb by removing the hose next check for power to the solenoid on the bottom of the carb a bad safety switch will shut it off they aslo stick from having bad fuel remove it clean it and check it for movement with power and ground
You should try completely shutting off your phone and getting it to start back up again. Many cell phones will have their power buttons the same button as the End Call red button. Hold the button down for a few seconds to shut it off, then hold it again for a few seconds to start it up again.
If you can't get it to turn off, try removing the battery and then replacing it and powering it back on. If this doesn't help it, you may need to replace your phone.
