GPS Logo
s
susan rutjens Posted on Oct 23, 2015
How do I get a code, so I can update?? - XL Tomtom GPS
raymond johnson
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Apr 19, 2016
raymond johnson
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
Helped
1218
Points
12
Have you paid for update and you are to enter code for updates
3answers
How To Fix Windows Error Code 0x80070652 In Windows 10?
The store error code 0x80070652 might be displayed for booting errors. There are detailed solutions proposed in the link below.
Solution -
windows error 0x80070652 solution
2answers
How To Fix Windows 10 Update Error Code 0x8024a105?
google it on microsoft answers forum , it will be there
STATUS CODE 4099-4174-1600-0700-C000-000E
Xbox.com has a handy search page to lookup error codes:
http://support.xbox.com/en-US/error-code-lookup
From that page, those is the answer and resolution they give, good luck:
" Error C000-000E occurs when you try to download an update to your Xbox 360 console
Problem
You see the following error when you try to download an update to your Xbox 360 console:
error code xxxx-xxxx-xxxx-xxxx-C000-000E
Update failed.
Note In this error code, the "x" digits vary.
This error message means your console could not download a software update from Xbox Live.
Solutions
To resolve this problem, try the following solutions:
Solution 1: Try installing the update again.
Solution 2: If you're having problems connecting or staying connected to Xbox Live, see Troubleshoot your Xbox Live connection.
Note You can also update your console software by copying the update to a USB flash drive or a disc and then applying it to the console. "
No puedo instalar 17 updates en mi desck tope aparecen estos 3 errores Code 80070570,Code 80200053,Code ffffffff
try this:
http://support.microsoft.com/kb/2607070/en-us
Download the update package for your 32-bit system, restart and see if it helps!
***JUST CLICK ON THE LINK, GET THE PACKAGE, RESTART AND SEE IF YOU CAN INSTALL THE UPDATES***
Pls i can't remember my nokia 6085 security code
hi
please backup all your data then download the nokia software updater then update your phone software [or re install if update is not available for your modal ] it will reset your phone to defaults security codes
Link for nokia software updater
http://www.nokia.co.in/support/product_support/phone-software-update
if any doubt replay me
1helpful
2answers
I want to update it software version via USB cable
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
1helpful
2answers
I can update my firmware version by device update application in phone. Every time i going to update it shows no update avialable. But update is avialable. My current version is 11.0.008. So how do i...
download nokia software update service, just like Sony erisson.
you cannot update your phone but air(internet)
you need to run update service and then connect your phone via dtat cable 1.3 and above
7helpful
6answers
Eurovox update codes
my euro-vox max channels not working please help me....
4answers
Windows update error 80240016
Could you download and run the program Dial-a-fix from http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
I have tried this with many computers and it worked all the time.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
