Question about NorStar M7310 Corded Phone
Release forwarding to external number
Call rings once and then gets forwarded to an external number
Fox Mully
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
To program a button to forward on Norstar (if do daily)
Feature * 1
Press spare button
Enter the * code, enter a few pasuses (Feature 78), enter the outside phone number.
i.e *88PPPXXX-XXXX
To program a canel button:
Feature * 1
Press spare button
Enter the * code
Posted on Oct 23, 2015
Phone rings once and gets forwarded
Hello there,
Call forwarding is a feature of PABX and Public Exchange systems so do you mean the phone rings once and then 'forwards' to another different telephone number ? If so, then you need to contact the company / person controlling your Lines as you cannot change this on your phone.
If you mean that the phone rings once and then goes on to Answerphone, then this is down to the setting of 'ring count' which is on page 40 of your user manual downloadable here http://www.manualslib.com/manual/117136/Panasonic-Kx-Tg2431.html
If this doesnt answer your question, these please ask again and try and give us more information to help you.
Sep 25, 2014 | Panasonic KX-TG2431 Cordless Phone
I have a KX-T7130 phone system with intercom. for the last 4 weeks, every phone will ring once and then the call gets hung up before I can answer it. I can use every phone to call out, but just can't...
Most likely NOT your phone system (anonymous)
Neither is it likely accidental...
What it sounds like you are getting is a "ring splash"
It is a token ring to let you know a call was forwarded...
My best suggestion would be to call YOUR OWN
number and find out who has been getting your call...
Or at least what kind of TREATMENT your callers have been getting...
Since this is a GLOBAL SITE... I would suggest you consult
your service PROVIDER.. for the appropriate enable & cancel CALL FORWARDING.
BELL-SYSTEM Codes to invoke and cancel
Codes: *72 and *73: respectively
Forward... *72 = ("star, seven, two")
*72 (wait a second dial tone) dial tone + (forward number)...
If the call is answered the FORWARD is complete...
(confirmation)
Else
Repeat the SAME dialing PROCESS
(OK: indicated by two stutter dial tones followed by dial tone).
((confirmation)).
Cancel FORWARD...
*73: To CANCEL forwarding... *73 = ("star, seven, three")
(again OK... Success is indicated by two stutter dial tones followed by dial tone (yet another confirmation))...
Hope this helps...
https://en.wikipedia.org/wiki/Carnac_the_Magnificent Carnac the Magnificent
May 24, 2017 | Panasonic KX-T7130 Corded Phone
How do i forward calls to an outside line on Nortel M7324
You can forward an extension that is not used at all, and has the lines assigned to ring that you want to forward to an outside number. In programming have the extensions set to forward on busy to the external number using 9+ the number desired. When you leave for the afternoon, take the handset off the phone, and replace it when you return. NOTE THIS EXTENSION MUST NOT BE USED BY ANYONE -- IF THIS EXTENSION IS BEING USED AND A LINE RINGS IN IT WILL BE FORWARDED OUT.
Mar 19, 2013 | NorStar M7324 Telephone
I'm not sure if the problem is the phone set or the PBX. I have programed the phone set to forward all calls to extension and it works great. But I can not get it to toggle the forwarding on and off...
Check out the instructions for setting forwarding no answer. *7104 xxx # sets the forward and the time it requires to forward is settable in the *713 ss where ss is the number of seconds from 00-99.
A ring cycle is 6 seconds, so 24 would be about 4 rings. Once you set forwarding, you really don't have to cancel it, as even if someone is on the phone, the call waiting and display tell you who is calling and you have the timer time answer or ignore the call.
Carl
Feb 15, 2011 | Panasonic KXDT333 Phone
Respected Sir/ Madam, Kindly help me. we are using Panasonic KX-T7730. I need to divert call for my mobile. how i can do this. i need this help badly. Thank You . Best Regards, Kiftheen.
you will need to dial *7102 9 phone number #
this will forward all your calls
external call forwarding needs to be enabled on your system and you really need ISDN lines
To forward calls ringing a group of phones - from a phone within the group dial
*7141 +group number - 9+phone number #
to cancel this dial *7141 +group number
Nov 13, 2010 | Panasonic KX-T7730 Corded Phone
How do you forward a phone call from this phone to a cell phone?
to forward calls...go to your phone service providers website and help section for complete instructions...
with most companies simply pick up the phone... wait for dial tone... press *72 wait for 2 beeps and enter the number (area code first) that you would like it to forward to...once you enter the number wait for the line to ring... once it rings and is answered you are all set!
if it doesnt ring or is in use.. try again within two minutes...you should hear two short rings if it is activated...
to deactivate call forwarding...
pick up the phone (in the office)
wait for dial tone and dial *73 or #73
you will hear two short beeps... it is then off..
Apr 10, 2009 | Panasonic KX-TS3282B Corded Phone
Number of rings
Sounds like you have either send all calls (SAC) enabled or your station is call forwarded to voicemail.
Disabling send all calls or call forward (as applicable) will solve the problem.
Feb 19, 2009 | Avaya Definity 6408D Corded Phone
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Jun 11, 2008 | NEC Electra Elite 32D-1 Corded Phone
Call forwarding with Treo 650
Call forwarding is not controlled by the device itself, but the switch which is serving your cell phone. Most carriers have a start code to change the number of rings before forwarding usually *74 send then press the number of second before forwarding each ring is about 3-5 seconds or something to that effect. If you contact your carrier they should be able to tell you.
Jan 08, 2008 | Palm Treo 650 Handheld
NorStar M7310 Corded Phone Logo
89 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
