I DON'T KNOW. MY MANUAL ANSWERING MACHINE HAS A SELECTION I CAN CHANGE. THIS MACHINE ONLY RINGS 3 TIMES IF OLDE MESSAGE NOT REMOVED. MY WALK AROUND PHONE HAS MENUE TO ADJUST RINGING FUNCTIONS. SEE YOUR MANUAL IF YOU HAVE IT.
If the problem is with an AT&T cellphone you will need to call them or go log in online to change that feature, however if it is with a Uniden Cordless Phone (the product this question is linked to) the directions below found in their manual should help:
From the base
1) Press [clock/menu] three times. The base displays the current number of rings (2, 4, 6, or TS for toll saver) and announces the setting.
2) Press [>>/select] or [<</select] until the desired ring time appears.
3) Press [set]. A confirmation tone sounds, and the answering machine announces the new ring time.
From the handset
1) Press the MENU soft key. Select the ANSW. SETUP menu, and then the RING TIME submenu.
2) Move the cursor to select a Ring Time (2 TIMES, 4 TIMES, 6 TIMES or TOLL SAVER).
3) Press the OK soft key. You will hear a confirmation tone.
You can change the number of times the phone rings before the unit answers calls. You can select 2 to 7 rings, or “Auto”. “Auto”: The unit answers after 2 rings when new messages have been recorded, and after 5 rings when there are no new messages. If you call your phone from outside to listen to new messages, you will know that there are no messages when the phone rings for the 3rd time. You can then hang up without being charged for the call. 1 Press OK. Select “Answer System”, then press >(Right navigation button). 2 Select “Settings”, then press >. 3 Select “Number of Rings”, then press >. 4 Select the desired setting, then press >. 5 Press End button
on answering machine you need to do the following:
1. Press menu 3 times
2. Press repeat/rew or skip/ff until 4 is displayed.
3. Press set/ringer to store it for 4 rings.
1) With the phone in standby mode, press the menu/clock key three times. You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll saver), and it is displayed on the main base. Then you hear the guidance for setting the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then the announcement “Ring time” followed by the new ring time. After a few seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
