First turn off water to faucet. There will either be a set screw or a screw under the cap depending on the style. Once handle is removed there is the bonnet, crescent wrench or channel locks will do the trick. With bonnet off you should be able to remove the white cap and steel ball revealing the spring and boot. That's what you replace. Reverse the order to put back together. And there you have it.
Yes there is a cartridge that you need to replace remove hot or cold just remember which take to Lowe's and match with new hot and cold ones also there is a spring and washer under cartridge that need to be replaced very simple to do Lowe's also carries those,can be removed with small screwdriver by sticking down middle of rubber washer and popping washer and spring out.
None of the model numbers are close to what you have provide. Perhaps you can pick out the model closest in appearance to yours. Links are available below each model for the dimensions and installation instructions.
A rebuild kit for a shower is pretty cheap for delta. the actual ball behind the handle maybe wore and not allowing it to seat properly and restricing water flow hot side.
Also if you take it appart the 2 washers and springs you might as well replace them also.
Replace washers and springs and the ball with shaft that handle fits to.
call delta and describe the round plate and the screw locatios. they can identify model. you need a new cartridge they costs $25-60. They may send to you for free.
You need to replace the washer on the stem. It's a Delta so it's possible that you have the type where the washer is actually in the very bottom of the manifold instead of on the stem.
Yes, It can be fixed but it isn't a washer. There is a replacement stem for the faucet . They are readily available at most big box stores and possibly the local hardware store. Bring your faucet model number with you.
Where can I get washers for delta 418sswf
See my reply Nancy. Home Depot or Direct. I gave you a link.
