When I want to operating radio or CD screen wuold not pop up
SOURCE: viera link started popping up on screen about 10
guys i got the same pron..any of u got a solution???
its really getting on my nerves
SOURCE: Panasonic NV-GS25GC faults When I switch on,
Some symptoms of a defective CCD
include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used
in digital cameras.
If seen on both your pc monitor as well as the camera's LCD then it's
likely a CCD issue and it's no wonder that it will be more expensive
than buying a new digicam. This is why you need to be exceptionally
careful when taking care of your camera since most are uber sensitive to
being damaged by the slightest miss-handling.
When a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs
This, isn't a good new, but hope helps to solve it.
SOURCE: Require an English Manual for a panasonic CN-HDS630RD
I have just purchased a Toyota Allion Car imported from Japna into Sri Lanka. It has a panasonic CN-HDS630RD radio/CD type system in it but all the instruction manuals are in Japanses so i cant read it . Pls send me a English Manual? Thanks . MY E-mail Is [email protected]
