You need to get the engine trouble codes by performing the "keydance" or using a code reader, then start checking fuel pressure at pump and regulator. Best luck. Amclaussen.
P0507 code idle speed is high than expected. Partially stuck open thermostat can make the computer think that the car is cold and command a higher idle speed. A small vacuum leak will also raise the idle speed. Throttle plate not fully closed cause this condition. Once problem is solved then clearing codes will leave computer monitors at incomplete which will still fail state inspection by driving the car over several days with a fuel tank between 15%-85% will allow them to run to completion. Ask your state inspector how many monitors need to run to completion the hardest ones to complete are EVAP, SEC.AIR, CAT.
i have downloaded need for speed undercover full version from vuze. i installed it successfully using the key supplied by the key generator. but when i am trying to run the game its again asking me the registration code. and its not accepting the code which i have used while installing. plz help me to solve this problem. [email protected]
