SOURCE: setup 32 inch sansui for digital reception
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information.
If you are on cable, you may have to check with your supplier to see if they carry local stations.
SOURCE: I have a 32
Look in your manual for a channel scan entry. It should be an item in your setup menu. What this does is re-scan for all the signals it can receive.
Once the scan is done, it should display all the channels that are viewable in your area
SOURCE: Sharp 32 inch lcd tv won't reconginze channels
You probably need to do a channel scan to find TV channels and progrma them to the TV memory. Using your remote control select Menu mutton and follow instructions for "auto channel scan"
Testimonial: "Great info and simple to understand"
SOURCE: How do you hook up a digital antenna to this tv?
Connecting a Digital TV Signal
To connect an digital TV signal source to the
display, connect a coaxial cable between the
ATSC input and the TV signal source. GO to www.retrevo.com and download the manual,it is free.
SOURCE: Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
