ULINE U-Line 2000 Series U-CLR2160S-01 Logo
Tami Hodges Posted on Oct 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water is not pumping up to the reservoir. If i manually put water in the reservoir it will make ice.
Richard Roberts
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 198 Answers
  • Posted on Oct 22, 2015
Richard Roberts
Expert
Level 2:
Mentor:
Answers
198
Questions
Helped
151912
Points
324
I just had the same trouble after connecting it to my new filtration system. Yes, if you pour water in with a funnel, it will make ice. You need to be wary of overflowing, as it will drip into the ice reservoir, so close the door quickly so overflow will come out the ice dispenser.
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Ice maker kitchen aid kuic18nnts won't pump water over chill plate. Replaced circulating pump still no water.
Does the circulating pump- pump water? Remove the hose that goes to the spreader bar and run the unit again, if it moves water as a new pump should check for blockages in that hose and spreader tube. Get back to me if this doesn't work please. Personal email address [email protected]...
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
4answers
I have a kitchenaid kuic18nnts1 ice maker. It only partially fills the water reservoir causing the pump to run the reservoir dry as the ice is formed on the plate. I have replaced the water level sensor...
Hi hhsawin ,
Have you already check to see any ice blockage in the fill spout tube, this is the hose that caries the water into the freezer section and to the icemaker. If the elbow & tube has a ice blockage, it is usually best to replace the fill valve and the shut off valve. You can try to thaw it using use a turkey baster to spray hot water into the tube.Also there is a solenoid that lets water into the ice cube maker, have a professional check it to make sure its working correctly. Please remember your safety in doing checking and repair.
Hope it helps.
Thank you for using FixYa.
Whirlpool Side by Side Bad Water Taste
Most "new" fridges with water dispensers and ice instruct the consumer in there manuals to "bleed" the reservoir by running a couple of large pictures of water thru it. I usually recommend dumping the first few harvest's of ice as well (I believe this is also mentioned in most manuals too). once that is done the water should be fine as any contaminants in the system/reservoir should be gone. you may try changing the filter after this, but it shouldn't be necessary. most ice makers do not have there supply water travel thru the water dispenser reservoir however. the water filling the ice tray should have no baring on the water you dispense into a glass to consume.
hope that helps.
good luck
Problem with KitchenAid KUIA18PNLS0 Under-Counter 18-inch Ice Mak
There is no solution. I have three kitchenaid ice makers and they do not work. The 18inch was under warranty. I had it serviced every friday until warranty ran out. I put an inline filter on the machine and it ran like a charm for three months, which is a first. It's out again! The two 15 inch same thing... inline filter and it worked for a month. Yes I have cleaned the machine over and over with appropriate products. It will turn on water fills but it appears as though the pump is not moving the water. Either way the machine worked correctly for two years only for the 15 inch and for the 18 inch one year.
2answers
Ice machine does not fill reservoir does not fill
Is there a water filter on the system? also the line might be clogged from the inlet to reservior
Top ULINE Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an ULINE Hardware and Accessory Expert? Answer questions, earn points and help others
