Question about Nintendo DS Lite Console
DS Lite I suppose this is worth a try as well 2 x DS Lite - symptoms - the units will not power up - if plugged into the charger the orange light comes on for 1 second and goes off I have just replaced Touch screens on 2 DS Lites, the replacement screens came with instructions (bad ones) which did not mention to cover the metal back side of the LCD. (i only read this on a forum afterwards). Also the 4 pin ribbon cable for the touch screen, i am unsure as to if the cable goes under the gold pins or over the gold pins, i have made several attempts with this connector but it always ends up underneath the gold pins but from the looks of the connector it looks like the ribbon should go over the pins. So either both units have been permanently damaged by the metal backed screens or the touch screen ribbon is the wrong side of the pins (im hoping for the latter) Any or All help will be much appreciated on this matter. Thanx in advance of any help Gary
Anonymous
The ribbon cable goes underneath the gold strips for sure... I have fixed many DS Lites and that is your problem... if you have bent any of theose copper strips then you have more problems. By doing what you did with the LCD and not covering the backs you may have blown fuse 2, or less likely fuse 1, I would try repairing or testing those fuses and I am sure you will find the problem and have your console back and working in no time. If not then see my website www.videogamerepairs.co.uk for details and send it to me!
Posted on Mar 02, 2008
Anonymous
Love on 20: did you make master saying the same thing over and over again? thats your answer to a lot of posts ...."get a new one, call them or google" nice...
L1Cupid..I believe I read earlier that they need to go over the connector not under, if I find where I read that again I will post it for you, good luck
Posted on Feb 17, 2008
Anonymous
    Problem Solver:
  • 31 Answers
Get new one or call nintendo 4 the # go to nintendo.com or google it
Posted on Jan 21, 2008
Hi, I can't get my Ds Lite to turn on. I plug it ...
you must have loose part into unit or power switch , it needs to be go to the tecnica l store
May 19, 2010 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
When i put my ds lite on the charger the light goes on orange and goes off and the power thing wont come on
it seems like the mobo is dead or a fuse has blown f1 or f2 or both, maybe worth replacing them to see if solves the problem u havent got anything to loose
Jan 13, 2010 | Nintendo DS Lite Console
When i power on my ds lite my green light turns on then turns rite bcak off and when I attach the charger it does the same thing.... What/s wrong with it?
Does the orange light come on when you plug it in? If it does, then it is a failure of either the DS's BIOS or its Memory. If the orange light doesn't come on, then the AC adapter is broken.
You can get a new adapter fairly easily, but it isn't worth trying to fix a BIOS or hardware issue.
If it's a fairly new DS, contact Nintendo's Customer Service, and see if they'll replace it.
Sep 19, 2009 | Nintendo DS Lite Console
Orange light briefly comes on and DS does not charge
is the charger socket ok as i understand they snap internaly also could be worth checking the battery.
Jun 27, 2009 | Nintendo DS Lite Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Not charging
Quite honestly...
I know that this is probably not the answer you guys want to hear about this issue...
You're going to have to contact Nintendo and make good on your warranty on this one. Just tell them that the unit is no longer charging and that you 'don't know why'. They should have no real problem replacing it for you.
This is most likely an internal electronics issue that no expert here is going to be able to advise on.
Unfortunately the internet still isn't good enough that we can do solder jobs over our internet connections. :P
=THIS IS NOT A PROPOSED FIX. DO NOT RATE ME FOR IT=
Otherwise, if you wish to persist in trying to fix your problem, the only thing that I can tell you is to either try using someone else's charger adapter, buy a new adapter OR use an adapter that works and hold it at different positions in the DS Lite to see if any position will charge it. If you are succesful at charging it in this manner then the port you plug the charger into may be loosened.
===DO NOT RATE ME FOR THIS POST. IF YOU GIVE ME A POOR RATING FOR THIS POST I WILL DISPUTE IT WITH THE FIXYA STAFF AND ASK THAT IT BE REMOVED. I AM NOT ATTEMPTING TO SOLVE YOUR PROBLEM BUT AM GIVING YOU ADVICE ON WHAT YOUR BEST BET IS. I WILL however accept a GOOD rating if it is given - naturally. LOL===
Regards,
Cyryl
Nov 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
159 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
