Vtech DS6421-3 - cordless phone w/ call waiting caller ID & answering system Logo
t
trish Posted on Oct 22, 2015
When my v tech ds6421-3 rings it immediately stops and goes to my cell, which is connected. It reads silence on the Vtech phine. How do I get it to ring on the Vtech
5 Related Answers
Anonymous
  • Posted on Sep 01, 2008
SOURCE: Problem when dialing phone
Yes, I have had nothing but trouble with my V-Tech ia5823.
Slow to dial, dropping out going calls and now the base light is flashing at a rapid pace and will not charge the handset.
I want to return it to Wal-Mart but have misplaced the recepit.
I will never buy another V-Tech..Uniden is the way to go!
Anonymous
  • 50 Answers
  • Posted on May 28, 2009
SOURCE: Phones stopped working. They only read
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
stwill2326
Steve Williams
  • 77 Answers
  • Posted on May 31, 2009
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
nature_lady1
  • Posted on Dec 18, 2009
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
  • 102366 Answers
  • Posted on Oct 14, 2011
SOURCE: i want to set the
Since you declined to specify the model of your VTech system, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to download a copy of the manual.
Stopping the phone from ringing when trying to avoid a call you don't want to answer
You will probably have to call your phone provider and request the number be blocked, that's the only surfire way.
Why does my iPhone 5c vibrate instead or ring?
You need to increase the volume from just vibrate to ring. You may also have slid, the tiny almost impossible to see switch on the top left hand side, and pushed to the vibrate only position. This tiny slide switch is useful if the phone goes off during a performance and you need to silence it immediately. Unfortunately, it is small and easy to switch on and off accidently, and many people do not seem to notice that has been switched. In one position, it will silence the ring and your phone will only vibrate. The other, the phone operates normally. I think it is a big design flaw on the Apple phones.
2helpful
Vtech;5.8 ghz'#cs5121-2: how do i silence the phone to turn off ringer and then turn it back on>
go to main menu select the option of ringing or tone set-up and then select ringer type select silent same procedure done turn back or u can also fallow guideline book
I am trying to figure out if i have a silencer ring on my turbo in my truck
Hi ,
It is easy to figure out silencer ring
A silencer ring is a metal baffle placed into the turbocharger inlet to reduce whistle from the turbocharger. It is installed in Ram truck engines at the request of Chrysler. The silencer ring has no effect on engine output, EGT, or boost levels. It does significantly reduce high frequency turbo whistle
On Removal: Remove the flex hose from the front of the turbo that goes to the breather. Just inside the turbo, you will see a snap ring that looks like a piston ring(charcoal color), very gently with a small flat blade screw driver, lift one end of the snap ring out of the groove, then continue to work around the snap ring, lifting it out of the groove. When the snap ring has been removed, you can easily remove the silence ring. You may want to keep the snap ring and silencer together in a plastic bag in case you get tired of the extra whistle.
Turbo
With Ring
silencer-t.jpg silencer-no-t.jpg Turbo
Without ring
2answers
No dial tone/ others trying to call get busy signal
there is no problem with your phone.Because the main problem is the simcard you are using...try to buy a new simcard
11helpful
1helpful
1helpful
Can send but not receive faxes.
Fax machines won't work reliably on a digital phone line.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
