Question about Garmin StreetPilot C330 GPS Receiver
Yesterday my car turned on the ABS, trac off and service vehicle soon lights at the same time. A few months ago, the front end started making an airplane noise. I chalked it up to a punctured exhaust pipe due to the construction at work. Also, I get a strong exhaust smell when I pull out of a parking spot in reverse. I don't want to drive my car in fear of something bad happening. I did some research and came up with the hub assembly for the noise and lights. Just asking to see what anyone else thought before I buy parts I may or may not need. I don't notice any change in the noise when I turn my wheel in any direction either. Thanks!!
SOURCE: Unit will not charge, changed battery but still does not work... Help
iQue 3600 battery replacement instructions:
http://www.pdainternalbattery.com/1a2w423c2install.html
Posted on Nov 20, 2007
SOURCE: Can not turn on my GPS Garmin nuvi 760
Can you try the direct to outlet charger? If you dont have one can you try a different charger? If that does not work then that means that the unit might be defective. Contact Garmin at 1-800-800-1020
Posted on Mar 07, 2009
SOURCE: The garmin nuvi 660 (has truck routes)the
Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Posted on May 24, 2010
SOURCE: Since a few weeks ago, when turned on, "GARMIN"
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Posted on Jan 21, 2011
SOURCE: I just got my 1490LMT,
I have the 1490LMT also and all the maps I have found on this unit and others are usually a year behind or more with new road changes. That is why I bought a LMT unit, because I did not want to pay for outdated maps on my 265WT any longer. This is a problem with most Gps units sold. May be if more people write to Garmin and complain they may do something. I have attached a link to Garmin for you to let them know.
http://www8.garmin.com/contactUs/
Thanks for using FixYa.
Posted on Jun 19, 2011
