It will get up to about 50 rpm and the load is balanced. The filter is clean and it drains properly. It will spin just fine on the manual spin cycle.
SOURCE: My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
SOURCE: The drum on my bosch wfmc1001uc won't spin but it
draining has nothing to do with spinning.
open the back of your machine and you can see the mechanical parts of your washing machine
try to turn it ON , just keep a distance enough for you to see,
1. check the belt if it is attached and aligned (if loose, tighten it a little bit)
2. check if the motor is running ( if not, check the capacitor-small aluminum tube with wires) if busted replace it.
3. check if there is any hamming sound from the motor, if make a humming sound but does'nt rotate, take it out and bring it to machine shop to replace the bearing or bushing
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
SOURCE: bosch wfmc1001uc spin cycle not
Welcome to FixYa.
Based on your post, "spin cycle not working" this is usually the bi-product of the unit not draining properly.
These are the steps I'd suggest you take to move forward...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful...I usually cover the edges with electrical or duct tape or wear welders gloves).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
( you should also see a ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
THIS RELEASES THE DOOR LATCH IF PULLED
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap.
Hopefully you'll find the item/debris that initiated the poor spin error here.
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, or door lock but I would certainly start by performing the things I listed first, the motor is very unlikely.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
