I am wanting to change the times that the phones change from night mode to day mode
SOURCE: Day Night mirror
I have had these mirrors apart and the problem is the little motor that switches the mirror for day or night, the only thing you can do is replace it.
SOURCE: How do we keep our
This has about 5 different conditions, so let me start somewhere.
Pretending your 7731 is connected to a recent Panasonic KSU, like a TA series, you have the ability to set the time by hand, or CID delivered in the first call after 2 or 3 AM will do it. If the sender is still on standard time (typical with VoIP delivered CID), then it will reset the clock to a different time (-1 hour) every day and it will be noticed if you set the clock and the first call of the day follows.
In addition, via programming from the main phone, you can set manual or automatic switching for day, night, and lunch modes. That procedure is outlined in the Programming Manual for your system, but it involves setting the clock times in Maintenance console 1.4 or programs 006 and 007.
If you absolutely want to never have to deal with clocks or night mode, then set 006 to manual and dial 781# on the intercom from the main phone (x101).
Note that this is only the solution for TA series KSU's.
SOURCE: Why is phone stuck in night mode?
Beth, Re POST year, make, model, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
