Question about NorStar M7310 Corded Phone
Out of all our business phones, only one will not ring for incoming calls. Not mute buttons. Adjusted volume and ringtone.
Posted by Gabie Ryan on
Rory DiSante
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Extension needs to be added to ring group
Posted on Apr 05, 2020
5 Related Answers
Anonymous
SOURCE: Only First Phone in the system will ring on incoming calls
No the manuals locates on the norstar website are just the tutorial telling theat hte hold button put a person on hold...we all know what the function of a hold button is or even a line button is...if someone has some real information please submit it! Oh and i have already tried calling norstar...they tell you to call meridian, then meridian tells you to call norstar...great customer service!
Posted on Jul 24, 2008
ynotphone
ynotphone
  • 192 Answers
SOURCE: Phone
Mute is not a feature of the phone system, but on the phone itself.
Pressing * 6 will not do anything, it changes the ring tone on digital set.
You are out of luck unfortunately.
Posted on Mar 20, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: I need to change which phone rings.
I guess this is alittle late... but for your knowledge:
First you need to know the extension of the phone that you want to change. Feature 0 at the phone you want to change and hit the intercom key to ensure that we are programming the right phone.
To get into programming press:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading..Enter->
<- Back .......Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension number of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Enter (the top right arrow) again then LINE ASSIGNMENT and hit Enter again
-> then you will see Show line:____ and input 001
-> it will show something like L001: Unassigned now press CHANGE till it says Appear&Ring
-> keep putting in all the lines that you want to ring at your desk
till all the lines are found (the numbering scheme counts out funny for Norstar it goes: line 001,002,003,004,025,026,027,028)
-> after you find all the Lines, you now hit RLS to back out of programming.
Voila, your phone will now ring. To change back, do all the same steps, but input Unassigned instead of Appear&Ring.
Posted on Apr 17, 2009
stwill2326
Steve Williams
  • 77 Answers
SOURCE: No mute - conference calls
sounds as if you will need your vendor to program your phone and others that need be to have Handsfree/mute capabilities.. i assume since you can not mute then you can not place your phone on Handsfree either.
Posted on May 29, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Jan 12, 2010
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
How do i increase the incoming and outgoing call volume
(For Kyocera Oystr)
Menu / Settings / Sounds / (choose topic) / (adjust up or down with button on side of phone) / save.
Ringtone volume, earpiece volume, key volume, speakerphone volume, etc.,
can ALL be found and set in the settings/sounds menu, and adjusted to your liking.
Nov 10, 2011 | Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
My iphone will not ring when called. I have checked settings and all look good. I can hear my alerts, alarms and when testing ringtones (and volume is up). However, when I receive an incoming call, i...
try checking the mute button on top of the volume buttons. if you see an orange dot or line, it is on mute so slide it to hide the orange dot or line and the phone should be fine.
May 09, 2011 | Apple iPhone Smartphone
How do i mute incoming call on samsung s7220
Hello Sir In Idle mode, press and hold # to silence or unsilence your phone.
And To change Your Ringtone follow these steps ! Change your ringtone Phone ? Settings 1. In Menu mode, select profiles . 2. Scroll to the profile you are using. > Voice call ringtone ? Edit
May 05, 2011 | Samsung Cell Phones
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Incomming rington volume
try putting on vibrate and ringer for incoming calls. i had that problem and it fixed it
Sep 27, 2007 | Samsung SCH-u740 Cellular Phone
NorStar M7310 Corded Phone Logo
123 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
