Question about Sharp AR-5316 Advanced Digital Imager Copier
Display of codes
My ar 5316 copier is displaying F2 ,U2 40, CH, and it is not able to make any copies, .
Posted by ibidun on
  • 2 more comments
  • Anonymous Mar 26, 2008
    Yes
  • SARAL Mar 26, 2008
    Changed the Copy Cartrdge EEPROM
  • Anonymous Mar 31, 2008
    Copier Makes Noise
  • Anonymous Jun 10, 2008
    error code h2
Darkfsg Masterss
    New Friend:
  • 9 Answers
Here is you need to solve this problem:
http://www.tradebit.com/filedetail.php/185184978-sharp-ar-5316ar-5320-service-manual
Posted on Aug 04, 2012
Anonymous
Holagru
uabnmxz
cvnaqgh
[email protected]
anug
q$dsf
asxfr
tgmnbv
gtas
asdxr
vtrs
hue
Posted on Apr 07, 2008
Anonymous
Holagru
uabnmxz
cvnaqgh
[email protected]
anug
q$dsf
asxfr
tgmnbv
gtas
asdxr
vtrs
hue
CheckitRight
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,363 Answers
Check my site under error codes/sharp :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Posted on Nov 16, 2007
2 Related Answers
Anonymous
  • 682 Answers
SOURCE: request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Posted on Apr 19, 2008
checkitright
CheckitRight
  • 1363 Answers
check my site and go to error codes look for sharp :
In sharp ar5516 F2 CODE DISPLAYED
Try this. On the panel. Press # * C *. Your screen will change to a diagnostic mode.
Enter the number 14 , as if you were going to make 14 copies.
You may have to enter 1 , then press start. But follow the display directions.
The 14 will clear F codes. This should resolve your problem.
Feb 18, 2011 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
What does it mean 3f shainning and flashing in copier
Unfortunately the service manual does not have this code listed. Maybe its an F2-?? or F5-??. Please reconfirm and respond. if you hold down the copy key it will display two more numbers.
Sep 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
I changed the toner catrige but machine is not functioning.
Is there any alpha numeric display on the quantity display LED such as F2 with flashing 04 or any other trouble display?
I will get back to you as soon as you can give this information.
Jul 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Request service manual for sharp AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
Never heard of an F2 on that machine. But give this a try.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
912 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
