Question about Xerox Office Equipment & Supplies
How to reset my toner level of xerox 7345 workcentre
My xerox workcentre 7345 is showing message cyan, meganta, yellow toners are empty, but these are full.
Posted by Thambiraja on
Sreenu Rebel
    New Friend:
For toner level you need to reset the values..
Posted on Jan 28, 2016
bvmihai
    Habit-Forming:
  • 168 Answers
You must reset or change the toner chips.
Posted on Mar 03, 2018
Gerardo Riz
  • 64 Answers
Tray to reset the main iot by from service mode
Posted on Nov 10, 2015
5 Related Answers
Anonymous
SOURCE: Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Posted on Oct 06, 2008
Anonymous
SOURCE: Any way to reset the toner empty sensor on C 3400?
THIS POSSIBLE SOLUTION IS FOR AN OKIDATA C3400N PRINTER ONLY.
You can try taking out the complete toner & drum assembly for the Cyan (or any you have this problem with). To do that you open the top and just lift the recalcitrant assembly straight up. Once it is out, with it oriented exactly as you lifted it out, look on the RIGHT end of the assembly for a small rectangular window - about 1/4" square. It should be about 3/4" below the two metal contact points on that end - near the top that you lifted out about the same level as the toner itself. In that hole, if it looks like the opening is covered (just inside) by a bit of black plastic, take a pointed object (like a straightened paper-clip) and try gently to lift this plastic piece UP - don't stick the clip in too far. If you gently do this (may take a try or two) that piece of plastic should stay UP - allowing you to see a bit farther inside. Replace the assemble, close the door and let the printer recycle.
Just to help you understand what may be happening - this little piece of plastic is supposed to start in the UP position when the toner is new. Eventually, as the toner becomes used up, the piece of plastic is designed to gradually drop down and eventually block the sensor - indicating to the printer that the toner is spent.
I have had this happened to me several times with new toner cartridges - especially with the non-OKI OEM knock-off "compatible" toners. This has always worked for me - but no guarantee it will for you!
The other possibility of course is that you actually have a bad toner, which trying this should help to confirm.
Posted on Jan 23, 2010
Anonymous
SOURCE: need solutons for xerox phaser
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Posted on Mar 26, 2010
Anonymous
SOURCE: does anyone know how to reset the toner levels in
Hey, I've just figured this out myself. Here is the procedure:
1. Open the front cover that gives you access to the toners. 2. Press and hold "Secure Print" and "Cancel" at the same time. You will see "K-TNR-STD" display on the screen. 3. Using the "+" and "-" buttons select the toner you want to reset. 4. Press the "Ok" button. 5. It will display "Ok?" and hit the "Ok" button again to reset the toner. 6. Close the lid.
All done!
Regards, Michael Pasqualone TotalServe Solutions
Posted on Nov 07, 2010
the chud
SOURCE: How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Posted on Dec 18, 2010
Toner empty error message
my dear you chek toner and change toner tenk
Jul 08, 2015 | Xerox WorkCentre 3119 Laser Printer
WorkCentre 7345 Fuser Assembly replace soon showing. please how i reset this
Replace the fuser assembly.
The fuser melts the toner ink onto the paper.
As such, it's a vital part of the printing process.
Mar 25, 2015 | Xerox WorkCentre 7328 7335 7345 7346...
How to change toner cartridge sensor in xerox workcentre 7345
Changing the Toner Cartridge sensor is not an easy task.
However if you want to start playing with the internals, firstly you would need to remove external panels.
some sensors look the same and are not interchangeable, but the ones that are, would be easy to spot. If you have a faulty cartridge sensor it would be interchangeable with the others.
Try it, and see what the response you get.
a Xerox service might pay you dividends.
Good luck.
Oct 24, 2014 | Xerox WorkCentre 7328 Multifunction laser...
This can be caused by a number of reasons. Continuous run of high density prints temporarily depletes the toner supply. The rest requires a service man because needs diagnostics routines and checking of the toner supply of the developer tank
Jul 29, 2014 | Xerox WorkCentre 7228 7235 7245 Yellow...
Cannot get new cyan toner for 7435 to be recognized.. may of been changed before asked for by machine... not sure what to do next
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
May 23, 2014 | Xerox Workcentre 7435 Color Multifunction...
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Unknown error 009-391
Remove Cyan Cartridge. Trun Off the Machine.
Now Insert Cartridge, make it properly inserted.
Trun On the Machine And The Error Is Gone......
Try It
May 20, 2009 | Xerox Office Equipment & Supplies
2,049 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
