LG TV : Picture not coming on screen, but TV is on. - Forums - CNET
www.cnet.com > Forums > LG
CNETJul 14, 2014 - Dear All, Have a peculiar problem with my LG flat screen TV. It stopped working suddenly, that is no picture when switched on, I noticed the ... However, in my case the RED light keeps on blinking and there is a ticking sound ...
LG Plasma Flat Panel 42PC3D - No picture just sound
Jun 11, 2015
No Picture from LG 50PS60 Plasma TV
Nov 16, 2013
More results from www.cnet.com
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... came on good with green light working properlybut still no picture.
SOURCE: 42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
SOURCE: LG TV completely dead
I'll think your power supply is down.
Since your tv is 15 month old, you've still got waranty left.
Just contact you supplier or LG service.
Kind regards,
Gerard
