The spring is for to put the rider in drive
SOURCE: L120 JOHN DEERE
There should be adjustments on the tie rod ends connecting to the front axles. Loosen set bolt, make the adjustment and re-tighten set bold.
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
SOURCE: John Deere ride on mower L100 17 hp.
my ride on runs well for 5 miutes then just stops wait a few minutes starts right up but does this over and over some help please
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
SOURCE: Drive-train failure -- John Deere L120 Automatic
my L120 does not want to pull itself up a grade or hill but will still go on level ground
