It does paper jam as the paper is touching the fuser unit every time i want to printer of photocopy. I have checked all the sensors, no problem, I checked the fuser in another machine and it is working properly. Evening the motor driving the fuser has been swapped but the problem persists.
SOURCE: Sharp AL-800 copier
If you check in the unit where the paper first leaves the paper tray, there is a small black lever called a sensor flag that should move freely in and out of a sensor led.Also one or two more inside the machine and where the paper exits the unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: "machine gun clicking" sound - fuser drive/motor gear area
Sometimes the clicking noise can come for the developer cartridge or the drum. you can carefully take them out and see if they turn freely.
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
SOURCE: Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
SOURCE: Sharp printer copier MX 4501N, how to remove the
Pull the paper tray to the front, after it is stuck pull it up ward and front
