That may very well be the case. There is a finite number of charge / discharge cycles a battery can handle. This number varies based on the level of discharge prior to charging, temperature, etc. Some devices can operate via charger alone - and others require a small amount of battery power and a charger to operate. A classic tell tale sign is an older device that has been used regularly and charged every day or night - but was allowed to fully discharge once - due to failure to connect to the charger. Attempting to charge may indicate it is accepting a charge but goes completely dead / dark when the charger is removed. That usually indicates a battery that was drained so low that it will need to be replaced. Good luck!
