Occasionally quite often not long ago in other takes more than 10 hours doing these beeps. can you please help me solve this problem. Thank you It changed the refrigerator temperature settings to see if this solves the problem. It also opens and both doors are closed and tightened a bit more to close it.
This refrigerator should have an alarm for an open door.
If the beeping is indicating a fault code, you should see this indicated on the display.
If no fault code is indicated and the alarm is due to an open door even with the switches pushed in, then you could have a bad door switch or a failed control board.
SOURCE: Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
SOURCE: Refrigerator Door won't stay closed
The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
Part 12 on this diagram is your cam.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSRB27FHSS02&productCategoryId=0165000&brandId=0593&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00006&componentDescription=REFRIGERATOR%20DOOR&documentId=O2030395&backToLink=Return%20to%20Sub%20Components%20list
Testimonial: "The most helpful and complete response I received. The link to the schematic was a great deal of help. You are a true Pro and I appreciate your help."
