Question about PfaFF 1163 Sewing Machine
You have a tension problem, Probably upper tension too tight but if not then the lower tension is too loose
Posted on Mar 02, 2016
SOURCE: Pfaff 7570 Sewing Slow
Unfortunately, this is most likely a computer board issue and there's just no way to predict if/when a board will go bad.
Your only option at this point is to take it to an authorized Pfaff dealer. If the person who serviced it was an authorized Pfaff tech, take it back to them. If not, do take it to a Pfaff dealer - non-Pfaff authorized techs are not trained on the machines.
Sorry I can't give you a simpler answer, but until this is corrected, your machine won't work properly.
Best,
Kim
Posted on May 04, 2008
SOURCE: LOOPS WHEN SEWING
This is a top tension issue, you need to check two things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset, and your local family sewing store will be able to assist you further.
-Chris
Posted on Jun 06, 2010
SOURCE: I am serging a 3 threat flat hem, thin, single
This sounds like a needle problem, put in a new needle and make sure it is the right system and size for your machine.
Posted on Jun 16, 2010
SOURCE: when I stitch , the
Sounds like you did not get it in the tension unit, try this.
Thread the m
Posted on Apr 17, 2011
SOURCE: I have sewn on my
Bobbin thread being too loose is due to two possible factors. The upper thread may be too loose allowing the bobbin thread to pull it under the fabric, or the upper thread may be too tight in which the bobbin thread will pull up to the top. Try adjusting the top tension to see if you can correct it. If it doesn't fix the problem, take out the bobbin and look for a screw on the bobbin case. If your bobbin case comes out from the underside of your machine, the screw is on the side. If yours is a drop in bobbin, it will usually be under the faceplate so you might have to take that off too to get to it. Turn the screw clockwise to tighten the bobbin, counterclockwise to loosen it. Only go a quarter of a turn at a time so you won't overshoot the mark.Then try by re-threading and sewing.
The basic procedure for threading is as follows:----------
Note that Pfaff sewing machines thread from left to right, not right to left like other sewing machines. The upper tension discs should be raised at their highest position while threading, and the presser foot should be raised up until you thread the needle. Drop the presser foot right before you thread the needle. The prevents thread problems during use.------------- Insert a full bobbin and retrieve the bobbin thread through the thread plate. Raise your sewing foot and needle to its highest position; hold the needle thread taught with your left hand, lower the needle into the thread plate using your right hand, and then raise the needle. As you raise the needle, the needle thread will catch the bobbin thread, and pull it up. There should be a loop of thread intertwined with the needle thread. Use tweezers, your finger, or a straight pin to retrieve the bobbin thread that is visible through the thread plate, and pull it through the plate.Place the fabric under the presser foot, and drop the presser foot. Choose the stitch you want to use from the top stitch display, right above the top thread feed. Press the '0-9" button located on the sewing machine's front panel, and a display screen will come up. Input the thread number, and press the 'OK' button located on the sewing machine's front panel.-----------this is procedure. If problem persists.Remove bobbin and clean lint from bobbin and re-tight the bobbin properly, then check.This should help.Thanks.Helpmech.
Posted on May 16, 2011
