Nokia E7 (16 GB) Smartphone Logo
Question about Nokia E7 (16 GB) Smartphone
Disassemble nokia e7
Power connector dislodged in phone. need to open up phone and replace or fix this phone connector. how do I disassemble the phone?
Posted by ibumax on
Dustin
    Master:
  • Nokia Master
  • 350 Answers
Posted on Oct 18, 2015
How do i fix error code E7 16 on my ar5516 sharp copier
E7-16 means abnormality in function of Laser unit. All you can do is reseat connectors, disassemble Laser unit and clean optical system. Otherwise replacement is required.
Nokia e7 connector
Do you want a Nokia E7 connector? If so, you can get it from any Nokia priority dealer.
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Reset password
  5. The process will do format to factory default Nokia E7.
Source: http://www.hard-reset.org/factory-default/how-to-easy-master-format-nokia-e7-with-safe-hard-reset/
My nokia E7 phone's charging pin is loose connection.has the mother board damaged?
it is difficult to know, because you need to open device and check or show some oficial repairer
7helpful
My nokia e7 won,t turn on. Worked fine when i put it on charge the night before and the next morning the screen was blank and i didn't managed to get any response out of my phone
I had the same problem with my E7, if you've already tried holding the power button down for 10 seconds then you'll need to remove and replace the battery, that fixed mine straight away. Just follow the guide below
1helpful
My E7 get hanged ,its not starting now.
I had the same problem with my E7, it just wouldn't switch on, if you've already tried holding the power button down for 10 seconds then you'll need to remove and replace the battery, that fixed mine straight away. Just follow the guide below
The phone rings continuously and wouldn't stop. Also, can not open the cover and bring out the battery
I had a similar problem with my E7, if you've already tried holding the power button down for 10 seconds then you'll need to remove and replace the battery, that fixed mine straight away. Just follow the guide below
2helpful
2answers
My nokia e7 gets hanged since yesterday...i cannot open the battery coz its under warrantee... so what do i do...
If the phone hangs then please take it to a service center and get it serviced there... even after the service if it hangs, then fight for a replacement.... Because Nokia N8 and E7 series comes with replacement warranty if you are not satisfied with it...
May 23, 2011 • Cell Phones
1helpful
NOKIA N95 8GB NO DISPLAY BKEY PAD LIGHTS ON
The LCD display has most likely failed or the internal connection to it has been dislodged.
Without special tools and equipment there is nothing you can do to fix this properly, although a dislodged connector can sometimes be temporarily reseated by giving the phone a sharp sideways tap. Doing this can also completely dislodge the connector, but as the display no longer works you have nothing to lose.
If the sharp tap solution brings the display back then all you've done is to confirm that you probably won't need a new LCD display but either way the phone will still need a professional repair.
Sorry to disappoint you but sadly not everything is fixable on a DIY basis.
Top Nokia Cell Phones Experts
Muzahura Frank
Kolbrun...
Marvin
Marvin
