Orion1934 19" TV Logo
A
Anonymous Posted on Oct 17, 2015
Why does usb memory unplugged show on my screen
My flash dose not work with ``please insert disk error`` and it shows in disk management `` no media ` please help me to solve it
Insert it into another computer, if it does show up, look for USB issues on the first computer, try unplugging any USB not nessessary, restart, try again.
If you cant see it on another computer chances are the USB drive went bad. Unfortunately they do go bad. Even reformatting it may only delay another crash of the USB Drive.
Good day to you. I have a Sony bravia.On my screen shows high power USB in a block and it also says unplug high power USB. the problem is there is no usb plugged in. what I do have plugged in at the back...
This may sound trite, but sometimes unplugging the set from AC then waiting about 30 seconds before plugging it back in will do an "AC reboot" of the processor. It may be just a data glitch causing the error.
If that doesn't help, you have a "hardware issue" on the main board.
[email protected]
ganti kata sandi baru
My camera suddenly the screen can not show the picture ...
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
When I plug my Olympus FE-220 into my PC, nothing shows up to let me know it's connected, and I cannot find where it is connected to the computer at all. My camera has a busted screen, and I want to be...
Hi turpy07, I'm guessing your using a version of Windows.What version are you running? You're probably plugging in your camera via a USB cable. When it's plugged in, there should be an icon on your tray (lower right) that says "safely remove hardware" depending on the version of Windows. Go to your start button and then either "computer" or "my computer", again depending on the version of Windows. Your camera, when plugged in should be listed in there along with your hard drives and printer. It may be under " Devices with removable storage". If you don't see it listed on your tray or under your computer, unplug it from your pc, and plug it in again making sure it's firmly seated. If it still doesn't show up, unplug it, and try a different USB port. If you're PC is new enough it may have slots for memory cards which you could just put the memory card from the camera in. Some printers even have memory card slots. Let me know what happens please. I'm here to help. Thanks.
Jeff
2answers
Blue screen error acer desk top
hi friend the blue screen comes when there is a 1:hardware problem
2:virus problem
3:Installation Disk is corrupted
4:RAM problem
First, check your CD and clean or replace it as necessary. Your next step should be to test your system memory for errors with a diagnostic program.
To do this obtain the Windows Memory Diagnostic or Memtest memory diagnostic programs on floppy or CD we mentioned earlier, and use it to boot your system and test the memory. If either of these programs shows any errors in your memory, you have likely found the source of your troubles.
Chances are you will need to purchase new memory. For more information on faulty memory and memory diagnostics, see PCstats Guide to diagnosing bad memory .
My Apple Sciphone says audio content error when I
hi dear
We briefly mentioned using junk data to overwrite the iPhone's flash as a last-ditch method of securely clearing off your user data yesterday, and although we were half-joking, that's more or less your only option until Apple provides a proper secure erase feature. Security researcher Rich Mogull has helpfully laid out the steps for you, and they're basically what you'd expect: restore your iPhone, don't sync any personal data to it, and then manually transfer three different playlists large enough to fill the flash. Essentially you're doing a manual three-pass overwrite, which is pretty much exactly the long and tedious process it sounds like -- but we wouldn't dream of selling or giving away our iPhones (or any other phone with personal data on it) without struggling through it.
2helpful
Want to update my sharp blue ray disk player bd-hp21u - does not play current disks
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
7" sunpak frame wont recognize usb connection
How do I get my computer to recoginze the connection of my USB?
2answers
USB Flash memory
i think your flash memory is damaged. Some times When you suddenly unplug your flash disk from USB this might happens. Due to this Operating system cannot read File allocation table from your Flash memory. Just connect with another Pc whether it can read the flash memory. if still fails. then your USB flash memory is damaged.
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
