Question about Amazon Kindle Fire HD
How do I get the back off to replace battery on my kindle fire
Tried charging with two different chargers, no success. Wont hold a charge for more than 1/2 hour, now none at all
Posted by Judi Lord on
ray gallant
    Top Expert:
  • Amazon Master
  • 68,315 Answers
Judi this is not a consumer replaceable battery , take it to a computer shop
Posted on Oct 17, 2015
My Kindle fire won't move past the start up "kindle fire" screen. what is wrong and how do I fix it?
Hello
Reset the Device:
If your Kindle Fire won't move, this doesn't necessarily mean that it's "broken" or has a major problem. The Kindle Fire has a tendency to become "stuck," meaning that it looks like it's "off" when it's actually "on" but it will not work properly because it's locked up. To unlock the Kindle Fire, do a reset by holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to get the Kindle Fire up and working again.
Charge It:
If resetting doesn't work, it's possible that your battery is dead. Try plugging the Kindle Fire into the charger and wait about 15 minutes before trying to turn it on again. If the device refuses to start up, try resetting it again.
If it still won't move, it's possible that you have a dead charging cable. Alas, the cables that come with the Kindle Fire are not known for their longevity. Try charging the tablet with another cord that has a Micro USB connection and see if the device responds. There's no guarantee that the charging cord from your smartphone will work with the Kindle Fire, but it's worth a try. If you get a bit of a charge, then you'll know that your Kindle Fire needs a new charging cable.
Try a Different Power Source:
if the charging cable appears to be working but the tablet still won't move, try plugging it into a different power outlet or the USB port on your computer.
If all of these troubleshooting tips fail, your Kindle Fire may have a hardware problem that requires professional help.
Visit here:
Kindle Fire Support
Apr 23, 2017 | Tablets & eReaders
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Why won't my kindle take a charge?
my kindle did that too. what I did was get a new charger and if that does not work go to best buy or any place that sells electronics
Feb 12, 2015 | Amazon Kindle Fire HD 8.9"
My kindle fire does not charge.
If you are truing to charge with a USB post then switch to a wall wart. There is often not enough voltage to charge from USB.
Feb 04, 2015 | Amazon Kindle Fire HD
Kindle fire stopped working/will not open
try pressing and holding the turn on button. if bit call customer service
Jan 31, 2015 | Amazon Kindle Fire HD
Kindle fire will not charge-got a new charger and it still will not charge- does it need anew battery and how do I do that?
The Kindle touch and the Kindle FIre are great devices for your reading needs. However, there are times when it becomes unresponsive and freezes on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch/fire. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding.
  • Hard and soft reset
    Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.
  • this might help you.
Dec 22, 2014 | Amazon Kindle Fire HD
KINDLE WON'T CHARGE
Are you sure your charger is working? Try charging another device with it, or try using a different charger. If you're sure the charger is OK (and plugged in!), try leaving the charger plugged in to your Kindle for a good long while, like 12 hours. If it still doesn't charge, or if the charge wears down after a short time, you might well have a bad battery. Unfortunately, later-model Kindles don't have user-replaceable batteries, and having it done professionally is not cheap. If it's still under warranty, make sure to have it fixed before the warranty expires.
Sep 25, 2014 | Amazon Kindle Fire HD
Why will my kindle not charge?
Be sure you've left it on charge at least 12 hours while switched off. If still no success, it could be a bad battery or charger. Try emailing or being phoned back by Kindle support at <https://www.amazon.com/gp/help/customer/contact-us>
Aug 11, 2014 | Amazon Kindle Fire HD
Why wont my kindle hd charge?
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
Jul 23, 2014 | Amazon Kindle Fire HD
Amazon Kindle Fire HD Logo
102 people viewed this question
Top Amazon Tablets & eReaders Experts
Ron Rak
Ron Rak
Marvin
Marvin
Jean Thiebaux
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
