Question about Chevrolet 2003 Chevrolet Blazer LS
Why is my 2003 blazer dieing on left hand turn
When I slow to stop and put left deracial on my blazer will shut down just like as if I shut it off
Posted by Cheryl Leavitt on
3 Related Answers
Anonymous
  • 396 Answers
SOURCE: Car dies when slowing down or turning.
Have the idle air control valve checked.
Posted on Aug 07, 2009
Anonymous
  • 248 Answers
SOURCE: when a try to accelerate my 92 chevy blazer will slow down
SOUND LIKE A FUEL FILTER PROBLEM...
Posted on Mar 08, 2010
jturcotte
Jeffrey Turcotte
  • 8984 Answers
SOURCE: I just put an new battery on my 2004 chevy
Hi, there may be a problem with the alternator or possibly a short in the truck. Do you have a voltmeter, or is there one in the dash? Voltage at the battery should be at least 14 volts with engine idling. If not or you don't have a voltmeter, remove the alternator and have it tested at your local parts chain. If you need instructions for removing the alternator or have any questions, please let me know. If the alternator checks out good, please get back to me for steps to find a short in the car. Thanks for using FixYa.
Posted on Feb 15, 2011
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Silverado shuts off when I slow down and turn in 4wd.
yes stop driving it on dry pavement....its normal for it to lockup
Feb 20, 2018 | 2003 Chevrolet Silverado 1500
My 1987 chevy blazer shuts off when stopping.
it sounds like you have fuel starvation. try cleaning out your carbourator
Oct 01, 2017 | 1987 Chevrolet Blazer
Truck dies when i stop or slow down
Here is the most common cause of surges and stalls and low idle rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Feb 17, 2009 | 2003 Dodge Durango
2001 Chevy Blazer (only 49,000 Miles)
Same thing happened to me. I took it to the dealer, no choice. They told me that it is the engine. Didn't want to hear that, but I guess I have no choice.
Nov 05, 2008 | 2001 Chevrolet Blazer
Chevrolet 2003 Chevrolet Blazer LS Logo
219 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
