Sony DCR-DVD608E DVD Camcorder Logo
Kaushik Saha Posted on Oct 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera not able to detect dvd. hence cannot record video.
abdul rauf
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Sony Expert 483 Answers
  • Posted on Mar 14, 2016
abdul rauf
Sony Expert
Level 2:
Dedicated:
Answers
483
Questions
0
Helped
95761
Points
726
there may be dust on the laser lens, if you have a cleaner disk please use it, in some cases you have to play this several times to clean the lens. use a Sony recommended disk only.
1helpful
How to connect Hitachi camcoder with laptop
Connecting to PC via PC Connection Cable
Use the provided PC connection cable to connect the DVD video camera/recorder to PC as shown in the last.
Note:
• No data can be written to the HDD, disc or SD memory card in this DVD video camera/recorder when it is connected to PC.
• The PC connection cable does not supply power to the DVD video camera/recorder: Use the AC adapter/charger
to power the DVD video camera/recorder.
• Before connecting the DVD video camera/recorder to PC, disconnect any cables or camera accessories (external
video flash, external microphone, etc.) other than the PC connection cable and AC adapter/charger.
• When connecting the DVD video camera/recorder to PC, the ACCESS/PC indicator will light green. While HDD or
a disc is being accessed, the indicator will light or blink orange. While an SD memory card is being accessed, the
CARD ACCESS indicator will light or blink red.
If you connect the DVD video camera/recorder to PC via PC connection cable, the PC will automatically recognise the DVD video camera/recorder. After recognition is finished, it may be
prompted to restart the PC: In this case, follow the instruction and restart the PC.
I keep getting the message...'Recording on disc disabled' or 'Drive Error"...just wondering if anyone knows how to fix this. The disc in the recorder is half used so I cant ec=ven look at what is...
Try reading the disc on a computer that has a DVD drive - should be able to detect what files are on it. If you can't record anymore, then the disc probably got "finalized" on the camera.
How to download video from Canon DC22
Please give me Degital JVC PC 810 Driver
Neither my computer or DVD player have been able to detect the disk.
before you try to play the disk, you need to finalize it as the camera needs to add the index to the DVD inable for the DVD player to read it.
try it and it will work, but always remeber to initialize your disk before recording on it
2helpful
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
2answers
Transfer To DVD Gives an Error that indicates the content is copy protected
Amazing, CCD-TRV68 is analog video camera and doesn't have any digital signal like copy right.
2answers
Panasonic NV GS 400 mainboard problem
What he probably means is that the IC that "Drives" the "Port' has been damaged or destroyed, a very common problem. Due to the manufacturing method, IE: Surface mount compnentry, there simply aint no "Simple Soldering problem" fix, at all... the actual IC, must be replaced... but this isn't actually possible..(well technicaly it is possible, but real hard to do) so hence the only other "Fix", a board replacement. Although ya DV outlet is kaput... If there is another output? say an A/V out? could you not use that as a work arround?
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
