Hotpoint Ultima WF860 Front Load Washer Logo
Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD860 Washer Dryer not rinsing properly. Leaves white residue on dark clothes.
Had this problem for ages, usually solved by running another cycle. Machine works fine apart from this. No errors codes. My wife is now putting me under pressure to fix or replace !
Posted by Sandy on
  • Sandy
    Sandy Oct 16, 2015
    Is it possible to increase the amount of water used during the rinse cycle ?
2 Related Answers
Andersk
SOURCE: hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Posted on Oct 07, 2007
Anonymous
  • 1294 Answers
SOURCE: keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Posted on Mar 08, 2009
My GE Model DDE 5300 Dryer leaves grease marks on my clean clothes. Is this any easy fix or is it time to buy a new dryer?
Probably dried grease that came out of a worn out bearing. With it's age it's time for a new one.
Feb 23, 2018 • GE Dryers
I have a lg wm2277 front load washer and the liquid soap cup gets clogged and when I open the tray after the load is finished, it will be full of water. I have tried cleaning the cup but the white stuff...
Switch to powdered detergent. You'll be much happier in the long run. Liquid detergent leaves a residue. Eventually the residue mildews. Powered detergent leaves no residue. Plus you will solve your current issue. Also skip the softener and use plain white vinegar in its place. The vinegar helps eliminate mildew and it also helps release Dey from your clothes in the rinse cycle.
1helpful
Ultima WD860 - dryer has been stuck with 1 minute left for about half an hour. Have turned it off but obviously my stuf is stuck inside.
Hi!
Please disconnect your WD860 from the power supply. The door lock uses electrical power to stay closed. After you unplug the machine from electrical power, just wait a couple of minutes and the door lock will be released.
Regards,
Bogdan
1helpful
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
2answers
Hotpoint ultima wd860; My washing keeps coming out smelling musty even though I use conditioner regularly. Is ther a filter I need to clean out. Thanks
you need to clean the draw and the inside of the draw and clean the rubber door seal all way round when you done that use a washer clean detergent whitch should be at a super market. and run it at 90 or 95 temp cottons wash it should stop the smell beacause dirt is buliding up so a good clean should stop it.hope this helps.
7helpful
2answers
Keeps going on test cycle
1helpful
2answers
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
2answers
Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
1helpful
2answers
Hotpoint ultima 1200 washer/dryer
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
