How to stop volume control from popping up on your ...
www.aoe3paradise.com/How_to_stop_volume_control_from_popping_...
My computer has a gray box in the center that has volume 100 on it how can i get it..... My computer has a blue square in the middle of the screen that has audio
SOURCE: menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
SOURCE: Won't shut off, buttons won't work, blue square in top left corner
Unplug the power cord for the monitor for a few minutes
SOURCE: gateway monitor, black screen with blinking power button
wjfarm48, Sure sounds like a power supply problem. How old is it? How many hours of use? Do you understand what a switch-mode-power-supply and an inverter supply is? If not, then here are your options. Check with Gateway to see if there is a swapout program. You box up and ship them your monitor+cash, and they return a REFURBISHED same model with new CCF tubes and inverter/SMPS. When you box up the monitor, follow this lead. "A 3 inch thick layer of breathable air shall be the only thing touching the lcd front panel" Next option is find some local TV/Monitor repair guy who can get parts and or replacement boards/CCFtubes from Gateway. Last but not least, is to repair yourself. Not Recomended.. But do a search on lcd monitor repair or Bad Capacitors In LCD Monitors or Repair of SMPS in LCD/FPD Monitors. Also check for videos on YouTUBE related to lcd monitor repair just for your own info. Here 's what you are dealing with. The light that makes your FPD bright white is generated by Cold Cathode Fluorescent Tubes (2) that require 600-1200vac at high frequency that is generated by an INVERTER which gets 12-24vdc from the SMPS. Almost the same technology is used in the new style screw-in curlie-que Compact Fluorescent light bulbs. Only they call the inverter a electronic ballast. Anyway, thats about all the info I have. Let me know how you make out in you quest to get your LCD up and running again. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
SOURCE: screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
SOURCE: padlock appears on screen
I have this monitor,got it used at the goodwill, padlock problem and the control buttons (eccept for power) did not work. I tried every solution posted with no success. Then I got brave, I dove into the problem. 1) remove base, four phillips head screws. 2) remove the back, five phillips head screws. one in each corner and one behind the base mount, thus the need to remove the base. 3) carefully pry off the back, it snaps on, so take your time. I found a butter knife to be very helpfull. 4) The buttons are sodered to an electrical board whitch is snapped into place so carefully pry up from one side,again I used a butter knife. The wires are sodered to the board, they do not unplug. 5) Using a can of air, blow into each button and trying to clean out the inside them. I'm sure they should probably be replaced but we do what we can. 6) Put it all back together. 7) plug it in and connect it to computer. start working the buttons, at first I thought it was a lost cause but after about a minute I was able to get into the menue, scroll down using the arrow buttons and turn the lock off. A $300 monitor for 40 bucks. I hope this message gets to you before you give up. GOOD LUCK, GMAN8773
