First unplug the power then plug back in it will restart. you should see
the front lights flash as it resets if that fails read on... The blue
to light will rotated blue led if wifi is working. double check your lan
cord coming from your dsl,cable or sat box.
on the back there is a
small hole use a pin to hard reset it. you have to hold the pin in for
around 10 seconds. This will reset it factory default. You may have to
log into it to enable wifi. usually after the reset. type 192.168.1.1
or
http://www.routerlogin.net or
http://www.routerlogin.com into your browser
a login screen should appear.
Username: admin
password: password or 1234
these are the normal default but may have been changed by someone setting up your router.
Router
do fail often they just die out of the blue. this is an older wifi
router failure may have occurred. if no lights flash or regain a solid
status then it may have died.. good luck
