Televison & Video Logo
Sammy Schmidt Posted on Oct 15, 2015
I need setup instrutions to set up my bush tv i broutgh with me from the uk
Need setup instrutions
How do I remove my Bush Television from Store Mode please?
Question edited for clarity.
Question moved from Misc to maker category.
How to Get a TV Out of Retail Mode
Techwalla https://www.techwalla.com > Tech Support > How To
Step 1. Press the "Menu" button on the TV panel or remote control.
A pop up menu keeps appearing on the bottom of ...
Dynabook https://support.dynabook.com > viewContentDetail
Some models of LED and LCD TV's have a STORE DEMO mode that puts demo icons and menus on the screen. To remove this feature the TV has to be set in HOME mode ...
User Guide - BUSH
Umc-uk.co.uk https://www.umc-uk.co.uk > Argos Alba, Bush PDF (Please note, 'Store mode' is for optimum default picture settings, however ... TV Guide is available in Digital TV mode. It provides information about ...
30 pages
Bush tv combi led24265dvdcntdfvpxy dvd will not play.
Have you tried DVD lens cleaner, More than one shop bought DVD disc and 1. Menu 2. Scroll down to installation press ok 3. Scroll down to first time installation 4. Scroll left for yes press ok then once reset follow on screen instructions to set this back up.
If this failed follow link below:
https://www.argos-support.co.uk/6693954-bush-24-inch-hd-ready-smart-tv-with-dvd-player-black
My bush 40-133fdvd stopped responding to my remote, I thought I’d broke it so I bought another genuine bush remote which surprisingly didn’t work, I read on a thread I’d maybe need to reset my IR sensor by...
Please try the following:
1. Press "Menu" button
2. Type 4711 service menu code
3. Scroll to shipping conditions
4. Press OK this will factory reset this TV
or if this does not work try:
2. Scroll to "Setup"
3. Scroll to "First Time Installation"
both will perform factory reset
if this does not help book a repair with:
http://www.umc-uk.co.uk/fixedcostrepair.php
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
1helpful
2answers
CANNOT RETUNE THIS TV BUSH TV DVD COMBO LY2211WCW
Press menu button then press 7935, if like me you bought a display model it will be set to hotel mode, this hides all the menus, once accessed switch hotel mode off, job done x
Lost Remote
You need the instrution paper that comes with the remote. If you lost that paper you can not set up the remote.
Artgirl
6helpful
Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
Remote control code list
The Konig IR9982 is not a universal remote control so there is no code to make it work your Bush TV. It is actually a direct replacement (electronic clone) remote for some Hitachi models.
You will need a direct replacement for your particular model, try http://www.remotesreplaced.co.uk/television/remote-control-bush.htm
Bush TV 2137TSIL
go to & ask for manul http://www.television-remotecontrols.co.uk/tv%20remote%20control%20model/bush.htm you will have to give model no.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
