How do you hook up a drain hose to a Fedders dehumidifier?
We lost the manual to our dehumidifier and need to reconnect the drain hose. It works so well it fills the tank every day or so. The drain hose is hooked on the outside but it doesn't work. The tank keeps filling and then overflows. Thanks in advance for any help you can give us.
Is there a rubber plug in the right hand mid back pannel ? if so you probably have a unit that can have a drain installed . If you look in the hole you will see a white plastic tube near the front of the unit . You can access it from where the tank slides in . it just needs a short hose and a garden hose adapter .
Pull out the water collection tray. You will see a small pipe (about 1/2" diameter) in the top of the area where the tray came from. This is the "drain" that fills the tray. Connect a hose to this pipe and run the hose to a floor drain if you have one. I used a section from an old garden hose for my unit. There also may be a small opening in the back wall of the dehumidifier to route the hose more aesthetically.
It might be a problem since these units were made by Fedders for Maytag which is now owned by Whirlpool :inhale: but I found part number FD9520-010 "drain hose". If not, a length of dishwasher drain hose with a male garden hose fitting on one end would work fine
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
