Question about Texas Instruments TI-30XA Calculator
How do I find the nth root of a number? For example, the 6th root of 4096.
Posted by Kenziee Wellyams on
5 Related Answers
Anonymous
  • 34 Answers
SOURCE: I need to take nth (8,5,4,etc) root on the TI30XA
7th root of 3.4 x10 (exp) 23
Solution:
Try it.
Have I solve your problem?
Thanks,
-engrkoiled-
Posted on Mar 27, 2009
Anonymous
SOURCE: multiplying exponential numbers
I am needing to find out what key I can push for an exponent. I have an exponent that is 2520 and I dont know what button to push for it.
The problem is as follows:
3000 ( 1+ 0.06/360) exp.2520
3000 ( 1.000166667) exp. 2520
3000 - 4565.72
Final Answer
1565.72
Now how in the world did they get 4565.72. What buttons am I needing to push.
Posted on Apr 03, 2009
Anonymous
SOURCE: Keystroke issue with TI BA II +...
ok so when you're typing it into your calc. like that don't type it in without parenthesis.
example:
2^3=8
to find the cube root of 8, you type in 8^(1/3)
DONT type 8^1/3 because that means that you raising the 8 by a one and then dividing that answer by 3
Posted on Jun 09, 2009
sivaranjini
Sivaranjini
  • 241 Answers
SOURCE: how do you find the nth root button on the TI-86?
9 square root(812) = 256.460523
Posted on Jun 22, 2009
k24674
  • 8092 Answers
SOURCE: nth root button on it89
There is no nth root button per se. But to take the nth root of a number is equivalent to raising the number to the power 1/n
Nth root of X= X^ (1/n)
Hope it helps.
Posted on Sep 23, 2009
HOW TO FIND CUBE ROOT OF A NUMBER ON fx-82ms
There are several ways to find the cube root of a number on a calculator. On this calculator, we can use the nth root button, by using the yellow shift button with the ^ key. Another way to do this is just to use the ^ key.
For example, the cube root of 8 is performed by the following key sequence: 8, shift, ^, 3.
Another sequence is: 8 ^ (1/3)
Good luck.
Paul
1helpful
Compute the nth root
The nth-root function is the right-shifted function of the square-root key, second column from the left, fifth row from the top.
In RPL mode, to calculate the third root of eight, press 8 ENTER 3 right-shift [nth-root] and get 2.
In algebraic mode, press right-shift [nth-root] 3 right-shift [,] 8 ENTER and get 2. (The comma is the right-shifted function of the SPC key on the bottom row.)
How do i use the radical symbol on my ti-30xs
The radical symbol is used to calculate square roots. It a radical has a small 3 to the top left of it, it means cubic root. It it has a a small n or a small x to the top left of it, it means nth root.
The way any of these roots works is one of the following:
Enter a number (positive for a square root or an nth root with n even) then press the square root button. The result is then displayed.
The other way is to press the root key then enter the number whose root you wan t calculate. The result is then displayed.
If you press the square root key and a radical is displayed withy a left parenthesis, you can be sure it is the second way.
HOW do I get the sixth root of 63717646
Not knowing the model of calculator you have I cannot say USE the Xroot key. But you can still use the general power key [^] if you remember that an n-th order root is equivalent to a power of 1/n
If the order of the root (n) is even you cannot use a negative radicand. The result is generally a complex number
nth root of ( 63717646)= ( 63717646)^(1/n)
6th root of ( 63717646) =( 63717646)[^ยจ] (1/6)
The result should around 19.98526696
3helpful
How can I find the square root of 39 on my ti-30xa? Also I would like to know how to find the cube of 9482... Help
Square root of 39: Press 3 9 [square-root] =
[square-root] is the key just to the left of the divide key.
Cube root of 9482: Press 9 4 8 2 2nd [cube-root] =
[cube-root] is the shifted function of the 0 key.
For other roots, you can use the [nth-root] function, the shifted function of the key above the divide key. For example, to calculate the fourth root of 16, press 1 6 2nd [nth-root] 4 =
Nth roots
Use the nth-root function, which is the shifted function of the y^x key just above the divide key. For example, to calculate the 5th root of 32, press 32 2nd [xth-root] 5 =
5helpful
The TI-84 Plus Silver Edition - when dealing with roots and powers - how do you punch in the third root of or the fourth root of... also, how do you punch in ...the 3rd root of 8 cubed? or the 2nd root of...
Press the MATH key to bring up the Math menu. Option 3 gives you cubed, option 4 gives you cube root, option 5 gives you nth root.
For example, 3rd root of 8: MATH 4 8 ENTER gives 2.
4th root of 16: 4 MATH 5 16 ENTER gives 2.
1helpful
example:
2^3=8
2helpful
Nth root button on it89
Hope it helps.
6helpful
Cube roots or higher
If you want to take the nth root, enter the root first then press math 5 and then the number you are trying to take the root of.  For example to take the 4th root of 1000, press 4, math, 5, 1000, enter.
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
