As above, it has started to make loud vibrating sounds when it is cooling.
It is most likely from the frame of the fridge that the compressor is mounted on vibrating on the floor
I use two door wedges ( available from the hardware shop and I push one under either side a bit to get clearance from the floor
the noise stopped but the problem is that there is nothing available on the market to replace the wedges
rubber buttons under the plate worked but to stop the noise they tend to make the fridge unstable when opening the door or the front of the fridge has to be adjusted up so that the door self closes
try that and if it works the you are on the right rack
if not you may have to get the compressor rubber mounts replaced as they may have collapsed and allow the compressor to hit on the plate
