Question about Music
I Have a Technics PR-305 Digital Piano that I have and really like. I went to play on it on October 12th. Certain notes with different chords weren`t sounding.
I have a Technics PR-305 Digital Piano that I really like. I went to play on it. and I played different chords certain notes on the chords weren`t sounding. I must be the circut board under the keyboard. Can that be repaired?
Posted by John-Michael Mahnke on
Bill Boyd
    Top Expert:
  • Music Master
  • 53,816 Answers
It can be repaired or replaced if the boards are still available
Take it to an authorized service to have it repaired and failing that some shops that repair micro wave ovens have the technical ability to repair items of this nature
may be a good radio technician or radio repair shop could also do the repair as it is basically an electronic ( wireless/radio) that is controlled by keys
Posted on Oct 14, 2015
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 | Music
I have a Technics PR-305 Digital Piano in which I play on. I took apart the Digital piano to get to the rubber contact to clean them. later on I went to turn on the piano and it didn`t work.
Attempted to clean? Not a good idea obviously...Take it apart like you did before and look at the wiring and imagine that you can divine the thing to reveal some logical explanation. If you used a contact cleaner or spray to clean, that could be death to that piano my friend.
Dec 12, 2015 | Music
I have I Technics PR-305 Digital Piano. I took it apart to try to clean the rubber contacts with rubbing alcohol. It improve some what, then later on I turned on my Technics R-305 Digital Piano.
I would suggest taking it into the nearest factory authorized repair center. Go to the Technics web site to find one in your area.
Dec 10, 2015 | Music
Hi I have a Technics PR-305 Digital Piano, that I had since the fall of 2001. I went to play on it on it today Some of the notes in the chords weren`t sounding.
Sometimes the contacts under the keys get dirty and must be cleaned. To do this you have to disassemble the keyboard,
carefully remove the PCB under the whole keyboard, locate the not sounding notes, remove tre siliconic stripe with the contact and gently clean the inside black conductive rubber pills with a cottonfioc and alcool.
Also clean the contacts on PCB.
Oct 12, 2015 | Music
I have a Technics PR-305 Digital Piano It was working at the End of October, but around the beginning of November 5 my Technics PR-305 Digital Piano made a loud humming sound, then it quieted down, I
Also, in addition to more info I need; look on p 91 of the online owner's manual linked below. Pay attention to Sounds and Effects, the first section therein. Follow the directions closely, esp., read pp. 26, 83, and 86 which are referenced for detailed help w/ sound issues. TECHNICS SX PR305 Manual Page 91
Nov 26, 2014 | Casio Music
I have a Technics PR-305 Digital Piano. I was playing a couple of songs on it., then about 5 days later. around the beginning of November I went to turn it on it made a loud humming sound from the sp
Yes it can.....but you will need the schematics and some test gear in order to do it.....and a soldering iron....what do you mean by no surround on the speaker?? Can you post a pic??
Nov 25, 2014 | Music
I Have a Technics PR-305 Digital piano that I have for a little over 12 years ago that I enjoy playing on very much, I have a distortion problem in my speakers it`s not very bad I was told in Fixya th
The Speakers can be replaced with any brand. The thing you need to know is the OHM rating for the speaker. OHM is also called impedance. Unless the sticker has fallen off the back of the speaker that information will be on that sticker. OHM rating MUST match the old speaker. For instance 4 OHM, 8 OHM, 16 OHM are common ratings. All different ratings but VERY important to get this correct otherwise you could damage the electronics of your instrument.
Aug 13, 2017 | Music
Music Logo
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
