Question about General Electric 4.5 DOE cu. ft. High-Efficiency RightHeight Front Load Washer with Steam in White, ENERGY STAR GFWR2700HWW
General electric washing machine not spinning ?
1 Related Answer
Anonymous
  • 6277 Answers
SOURCE: General electric company washing machine model
This is symptomatic of a malfunctioning water control valve not closing correctly- its 'no power/default' position. It's the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 11, 2011
Washing machine won't drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Washer won't drain. Cleaned hoses and pump. Motor gets hot and just buzzes.
heatman101
Won't spin out washing machine
heatman101
WON'T SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
GE clothes washer WHDSE820C1WW started filling itself up and i cant get it to discharge the water out, spin or anything
heatman101 .
The machine is not spinning or draining
heatman101
Doesn't start spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
1helpful
No spin
hello mam
after thumble wash if the washer is not spinning the problem is in the programmer also there might be loose connections at the programmer.please check it.
7helpful
2answers
No spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
General Electric 4.5 DOE cu. ft. High-Efficiency RightHeight Front Load Washer with Steam in White, ENERGY STAR GFWR2700HWW Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
