Toshiba estudio 305 Copier Logo
s
showkat sikder Posted on Oct 13, 2015
I want to make a3 size print from computer - Toshiba estudio 305 Copier
ADCSFXworks
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Jul 24, 2016
ADCSFXworks
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
16078
Points
54
Simply go into the printer driver and set paper format for A3, and set it also in the application that you are using (Ex. Word 2016)
Best Regards
Carriage hp paper
Since A3 is twice the size of A4 I doubt it but... Does A3 size fit in the paper tray? If so you may be in luck but the original CD should have had the right driver, go to Lexmark site.
Send a A3 to print and it prints to A4...how to change this
when you give print command, go in printing preferences select paper size A3 and out put size A3. then printer will print on A3
1helpful
2answers
Canon IR 2870 A3 printout tail crumpled
Hello sir; When you print A-3 size paper did you set up on computer for a-3 size paper, most case A-3 size use in europe, usa use letter size. I hope that's the problem,
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
1helpful
I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Hp deskjet 1280 unknown a3 paper
Uninstall the HP 1280 driver and install HP 1220 driver. it will print on A3 size.
Ajay
Canon Imagerunner 210S - A3 error
A3 is a metric size paper. The document you are trying to print must have been formated for metric size paper. When you print select "Fit to printer margins" De-select "Choose paper source by PDF page size" and select the proper page size and source.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
